"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Q-T Thread
Old 05-20-2013, 02:59 AM
  #126
GallopingGhostler
GallopingGhostler's Avatar
Default RE: Q-T Thread
At this point I have already glued the stock cheek cowls in place, so I am beyond the point of no return. Of course I have The Real Thing kit I plan to build in future, so it holds definite possibilities.
Old 05-20-2013, 06:33 AM
  #127
Andrew
ORIGINAL: GallopingGhostler
The horsepower and RPM figures between the TT TP-07 and Cox .074 Queen Bee were similar. I suppose this was to be expected as both are sport engines rather than high performance engines.
George
Looks like you're starting to really breath some new life into the old gal - that wing looks slick as a whistle.
I think you'll find the GP-07 performs head and shoulders above the QB, not so much in power, but in reliability, throttling and overall good behavior.
Old 07-08-2013, 08:43 AM
  #128
steveshobbyroom
Hey guys finally got some more progress done on the scratch build. Time to cover! Looking to cover with monokote natural color / khaki or similar to give it a vintage look. Probably add lightweight wing struts too mainly for looks.
Old 07-08-2013, 09:06 AM
  #129
hllywdb
hllywdb's Avatar
Looks Good Steve. I like the antique colors on mine, they just have a nice airframe for it
Old 07-08-2013, 09:27 AM
  #130
dmbaerry
dmbaerry's Avatar
looks great.. love the new front end (cowl)
Old 08-29-2013, 11:36 PM
  #131
MrGoodwreck
MrGoodwreck's Avatar
Anybody flown theirs yet?
Mine is still sitting here....
Guess I should be getting to work.
Old 08-30-2013, 03:40 AM
  #132
GallopingGhostler
Originally Posted by MrGoodwreck
Anybody flown theirs yet? Mine is still sitting here.... Guess I should be getting to work.
I'm with you MrGoodwreck and in a similar bout. Other priorities have delayed me, but my repairs are near finished, just need to complete them, break in the TT GP-07. Meanwhile, I've been flying my Sureflite 40" (1,016mm) wingspan foam Cessna 180 with Norvel .061 Big Mig CL. (Photos courtesy of Gary Jones, MADS RC Club.)
Name:	Cessna 180 Banking.jpg
ID:	1914726   Click image for larger version
Name:	Cessna 180 Above.jpg
ID:	1914727   Click image for larger version
Name:	Cessna 180 Launch.jpg
Old 08-30-2013, 04:16 AM
  #133
takEon
My very first R/C plane was a Q-Tee. I had a Black Widow in it and it flew very well. I had to shoe horn standard size servo's in it as I was a kid with a limited budget ( small servo's were expensive back then). I wore out about 3 of them. Lots of great memories.
Old 10-20-2013, 04:58 PM
  #134
OzMo
OzMo's Avatar
There is an ST KIT on the fleabay right now
Old 10-20-2013, 06:21 PM
  #135
GallopingGhostler
Kit looks clean: http://www.ebay.com/itm/290998321926 got 7 days left to closing, thanks for sharing, OzMo
Old 10-25-2013, 07:32 PM
  #136
OzMo
OzMo's Avatar
still there but i'll scratch build for that $
Old 10-25-2013, 08:31 PM
  #137
GallopingGhostler
Yup, you can build a lot for $61 in balsa (going cost as of now). In fact, one could cut parts for several and have extras, too.
Old 10-26-2013, 07:30 AM
  #138
hllywdb
hllywdb's Avatar
Yep, some of us NEED extras
Old 10-26-2013, 01:57 PM
  #139
GallopingGhostler
You know what they say, hllywdb, here today, gone tomorrow.
Old 10-26-2013, 02:08 PM
  #140
hllywdb
hllywdb's Avatar
If I only had a dollar for the ones that were "Here today, gone today".......... I am getting better about that though.
Old 10-26-2013, 02:21 PM
  #141
GallopingGhostler
Yup, doesn't happen as often now, but when I was younger and less experienced, I Figure-9'd a 1/2-A pylon job on first flight. Crash was thorough enough that it wasn't worth rebuilding. (Had a light fuselage and foam wings.) It's not the only Figure-9.
I saw a club member lose control of a really nice large (1/5th scale?) ARF bipe gasser several weeks ago, about 150 yards out and straight in from 100 feet. It rekitted itself to kindling. Planes are a temporal part of this hobby.
Old 10-26-2013, 04:10 PM
  #142
Andrew
Originally Posted by GallopingGhostler
....................Planes are a temporal part of this hobby.
LOL --- never thought of it that way.
Old 10-31-2013, 06:17 PM
  #143
GallopingGhostler
Sometimes, the simplest solutions are the best for an old repaired airplane. Installing the TT GP-07 will require a new throttle servo, extending the needle valve and I don't have the proper threaded lock pin. A screw will work but will require trimming away a significant portion of the left cowl cheek, plus installing a fuel tank.
Due to close fit and servos are already placed, I finally decided to complete this plane by installing a Norvel .061 Big Mig CL engine with the 1/2 oz (15 cc) CL tank, with pick-up tube relocated to the bottom for more complete fuel tank emptying. Previously I used this engine on a venerable Sure Flite 40" span foam Cessna 180 of the 1980s. Even with the Mecoa standard long glow plug head with additional cooling fins (Texaco?), it pulled that plane briskly along even in windy days. This Q-Tee is considerably lighter, and as a two channel it will really move along, with generous tail control area, should be a decent stunt plane.
For me, it is evil but Happy Halloween. My Q-Tee should be ready for flight in the next few days.
Name:	Q-Tee Norvel 061 CL Engine.jpg
Old 10-31-2013, 06:28 PM
  #144
catracer343
catracer343's Avatar
You're going to love that motor on it! Mine's powered by the same setup turning an APC 5X2 when I want to putt, and a 5X4 when I want to zoom! I moved my firewall back about 3/4" when I built the kit and it fits perfect!
Old 10-31-2013, 06:33 PM
  #145
GallopingGhostler
Certainly got to agree with you there, catracer. In this case I am using a 6x4 Masters prop, with the slightly lower compression it should pull this thing along with even more authority than with the heavy foam plane. I'm thinking I should be able to do a loop from level flight. When powered by a Cox .049 Black Widow, I had to build up speed from a dive to get it to that.
Old 10-31-2013, 08:27 PM
  #146
GallopingGhostler
Q-Tee substantially completed, ready for receiver and battery installation, and flight testing.
Name:	Q-Tee Completed.jpg
Old 11-12-2013, 09:38 AM
  #147
GallopingGhostler
Test flew the Q-Tee yesterday, getting in 2 flights with less than 5 mph breeze, sometimes gusts to 8 or 10 mph. The Norvel .061 CL/FF Big Mig is a really sweet engine, really hauls this 17.4 oz plane with authority. (Cox .049 Black Widow kind of poked along. ) Slightly tail heavy, so was somewhat touchy on the elevator, but still manageable. Had a helmet cam (Vivitar DVR480), but need to adjust azimuth down as it only caught Q-Tee at the top of a loop. This is definitely not a windy weather flier, but on a lazy summer day, would be a total blast especially with the generous tail control surfaces, might even catch a thermal.
1/2 oz (15 cc) Norvel CL mount tank gives decent flight lengths of about 7 or 8 minutes of flight time. The Cox .049 Black Widow had an 8 cc (0.27 oz) integral tank and correspondingly half the flight time. However, I'll need to add another vent pipe to the Norvel tank so I can stunt. The end of the vent is at the bottom of the tank, so tank acts as a Uniflow. But when seriously changing attitude (like in a loop) engine cuts out when vent is no longer submerged in fuel, changing venturi feed pressure. Solution is to drill an air tight hole at the bottom of tank and extend another brass vent tube to top of tank, so fuel is always at atmospheric pressures.
