Control Lines For all you fly-by-wire fanatics!
Enya .45 series 6001
Reply
Old 01-08-2008, 03:40 PM
kersplat
kersplat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Enya .45 series 6001
I just ordered an Enya .45 BB series 6001 from Enya Direct.. It is U/C and has not one, but Two Piston rings. I think I will have to put this one in my will, I'm sure it will still be running long after I'm dead. [>:]
WaHooo!
kersplat is offline
Old 01-08-2008, 06:23 PM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enya .45 series 6001
I was very tempted to buy one too but it's not long since I bought the new 60-IIIB. I've still got my old 6001 .45BB that I used back when I was into serious stunt and it was at least as good as the ST 46 that most of the others were using. My fuel was just 75/25 all castor and once a year or so I'd take out the piston, give it a good clean and put it back in again. After 4 or 5 years ( and I'd guess a couple of hundred hours) it wasn't starting first flick anymore so I gave it a new set of rings. Back to being a new engine again for a few dollars .
downunder is offline
Old 01-08-2008, 08:58 PM
kersplat
kersplat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wonder if the carby for my Enya .29 will fit this engine. I think it would make a good engine for a scale plane using my Ureely Three line handle. Down Unda, do you know if this engine has a bushed rod?
kersplat is offline
Old 01-09-2008, 09:07 AM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, it's got a bushed rod but the 29 carb won't fit because the 29 has a 12mm bore for the carb while the 45 has only an 11mm bore.
Old 01-10-2008, 06:43 PM
colingw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can someone suggest a model that is a good match for the .45-BB? My experience poops out at .35 size models - never flown anything bigger.
I hope Enya are doing really well with their control line engine sales - it is great to see them supporting the C/L community like this.
thanks,
Col
colingw is offline
Old 01-10-2008, 08:31 PM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Col
There's a guy here in Adelaide using one in a Nobler and it flies great, the engine's just loafing around with it but personally I'm not fond of the Nobler because they're a bit small at 500 sq inch. A Brodak Vector is getting closer to a decent size with almost 600 sq inch.
Old 01-10-2008, 11:33 PM
colingw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.
Just looked at the Brodak site. The Vector as currently kitted is only 536 square inches, and max of .40 recommended.
I'm thinking Profile Pathfinder looks like a nice match for the .45BB. Plus I like the simplicity of profiles and sidewinder mount.
http://www.brodak.com/shop_productde...ProductID=2564
cheers,
Colin
colingw is offline
Old 01-12-2008, 10:13 AM
lukesp
lukesp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought my Enya 45-1 and it arrived the other day. It comes with two venturis, they appear to be 7mm and 8mm (I didn't want to take the fitted one out and mark the engine, so the quoted size is a guesstimate), the 7mm one being fitted. I have been bench running an old RC version of this engine that I bought from $bay a year or two ago. The run on the bench is very nice indeed, a nice stable four stroke.
I am quite curious to see how long these engines sell for considering how quickly the 29 and 35 sold out. And kudos to Enya for continuing with their support of C/Liners. From 09 up to 61, no one else seems to be doing that.
lukesp is offline
Old 01-12-2008, 08:35 PM
cutaway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PAW seems to have a pretty complete line of C/L diesels up to .60 size.
cutaway is offline
Old 01-13-2008, 03:37 AM
lukesp
lukesp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I forgot about PAW.
lukesp is offline
Old 01-13-2008, 09:49 AM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
........and Stalker who have a full range of sizes in rear or side exhaust and not an RC engine in sight .
Old 01-13-2008, 09:23 PM
colingw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm surprised the .45BB hasn't sold out, given how fast the .29, 35 and .35BB went.
I really hope they do well, particularly as I was one of the troublemakers who emailed Ken Enya agitating for a return of the .45 :-)
colingw is offline
Old 01-14-2008, 05:53 AM
colingw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, my .45BB turned up a mere 4 days after ordering it. Sterling service from Enya as usual.
What a beautiful engine! It turns over as smooth as anything (distinctly smoother than my new .35-III which is a bit grabby at top of stroke). Amazing retention of compression for a ringed engine. I solemnly pledge that it shall never see glow fuel containing an oil other than Castor!
Can anyone comment on my proposal to build a Pathfinder for the .45BB? Good match? I love the look of that plane and hope the Enya .45 might be a good fit for it.
cheers,
Colin
colingw is offline
Old 01-14-2008, 09:17 AM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That Pathfinder should be fine, it's got reasonable wing area. It seems to have a wire pushrod for the elevators with a guide half way along which may keep it from bending on up elevator but I'd suggest a carbon fibre pushrod. Go to an archery shop and have a look at some of their aluminium cored CF shafts, they're surprisingly cheap and work great. I'd also suggest using an RC clunk tank which can easily be set up as a Uniflow if you prefer. There's one brand called IM that I'm using on a profile model which is perfect because it's got a taper that's wider at the back when laid flat against a profile fus. This means that the last drops of fuel go to the outside rear edge so the clunk picks up everything.
Old 01-15-2008, 12:48 AM
lukesp
lukesp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Same here. Very nice eh?
lukesp is offline
Old 01-15-2008, 12:59 AM
lukesp
lukesp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gads. If I knew what I was talking about I'd be dangerous. [sm=47_47.gif]
lukesp is offline
Old 01-15-2008, 08:24 AM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: lukesp
Well not really because Enya is the only mainstream manufacturer actually doing something for CL. Stalker, Jett, Nelson etc are hardly mainstream . I guess we could include Super Tigre though because their CL G51 (different timing to the RC version) is superb.
Old 01-15-2008, 04:42 PM
lukesp
lukesp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most gracious of you Donwunder, and yes, mainstream is what I meant .[sm=what_smile.gif][sm=thumbs_up.gif]
lukesp is offline
Old 01-15-2008, 06:53 PM
colingw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, Stalker's offerings start at the "serious C/L stunt" threshold of .40. Enya are the only manufacturer doing a comprehensive ranges of the smaller sport flying sizes.
As best as I can tell, Enya now offers a control line range that has never been surpassed in quality, reasonable price or variety in the history of C/L.
What other manufacturer offers :-
.09 - 2 versions (cross flow in both plain & BB)
.11 - schnuerle BB diesel
.15 - 4 versions (cross flow, schnuerle, schnuerle BB and schnuerle BB diesel)
.20 cross flow - very light weight for the displacement.
.25 - 3 versions (2 schnuerle glows and a .25 diesel that can swing up to a 12" prop)
.30
.35
.40 - 2 versions
.45 - 2 versions (cross flow & schnuerle)
.50
.53 C/L four stroke (recently announced)
.60 - 2 versions (cross flow and schnuerle .61)
.. and then backs it up with great parts service and limited edition releases of old favourites that are 20-30 years out of production?
For the sports flyer like me, this makes Enya my first port of call when I want a new engine of high quality, unless I happen to be in the market for a diesel in which case its a toss up between Enya (if they offer the displacement) and PAW.
If I ever reach a competitive level flying F2B, then it will be time to look at the specialist F2B engines, although I suspect a talented flyer could do pretty well with a .53 4 stroke, .60-IIIB or 61CXS Pro.
cheers,
Colin
colingw is offline
Old 01-15-2008, 08:36 PM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: colingw
Currently I'm using a Stalker PRO61RE in my stunter and the previous one (same design) had a G51. I can't really tell much difference powerwise between the two. But I'm seriously thinking about grafting in my Enya 60-IIIB to see how it compares in flight to the Stalker. I suspect it'll do very well .
Old 01-16-2008, 10:06 PM
colingw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that is a comparison I'm interested in - how do the .60-IIIB and .61CXS-Pro hold up when compared to the likes of a Stalker .61? Also which of the two .60 size Enyas is the more usable for C/L? The new .61 seems like a mighty powerful engine for the weight.
colingw is offline
Old 01-26-2008, 02:36 PM
kersplat
kersplat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I started my breakin runs on the .45 today. I am using a MAS 10X7 runing at the rich end of four cycle, Man at this setting the engine can pull a barn. If it has this much thrust at an extreme rich setting with 5% nitro , it should not varnish up too soon running so cool.
kersplat is offline
Old 02-28-2008, 01:04 AM
kersplat
kersplat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's one for ya Downunder. I bought an R/C Carby from Mr Enya for my 6001 45. Will this engine run well as an R/C version? Or is the timing set up too much for U/C?
kersplat is offline
Old 02-28-2008, 08:52 AM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep...it'll run fine as RC, in fact in a discussion in RCU quite some time ago there was some agreement that a converted CL stunt engine is just what's needed for 3D type flying. Lowish revs and a big prop .
Old 03-01-2008, 09:33 PM
kersplat
kersplat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOWEE, you were so right downunder. The Enya .45 series 6001 is an amazing engine with a carb. What a top end, what an idle. This will work real well as a U/C carrier engine! I'm so glad I bought the carby for it. Thanks for the advice.
kersplat is offline
Reply
Display Modes
