synth. mod acting wierd?
NC
when I use the sythesizer module in my 9Z wc2 the servos in the plane dont move as smooth as with the original single channel module. kinda goes in steps when you move the sticks smoothly from one side to the other. then when using with a gws rx, some mixing of rudder goes on when you use any other channels and I have no mixing programed in radio ? any suggestions
RE: synth. mod acting wierd?
We'd not know why you're getting 'stepping' when you use the Futaba synthesized frequency module with Futaba receivers and servos. We'd need to see the unit. As far as working with non-Futaba equipment, you'd have to discuss that with that particular maker.
If you wish, we'll be glad to examine your Futaba equipment to see what the difficulty may be.
