DLE-30 - Post your prop data here
OH
Thought I would ask if you guys would post your prop data here so it is all in one spot.
DLE - 30 PROP DATA
<pre>
User Prop RPMs
Daddysam Zinger 18-8 8000
Daddysam Xoar 18-8 7800
AWD JXF 19x8 7450
gen3v8 Top Flite 18x6-10 7600
gen3v8 Winsor classic 18x8 8300
gen3v8 APC 18x8 8940
bcchi Mezlick 18x8 8500
bcchi Xoar 19x8 7400
rcign JC 20x6 7600
mpascual MenzS 18x8 8350
mpascual MenzS 19x8 7330
mpascual MenzS 20x6 7230
</pre>
DLE - 30 PROP DATA
<pre>
User Prop RPMs
AWD JXF 19x8 7450
rcign JC 20x6 7600
</pre>
OH
RE: DLE-30 - Post your prop data here
Thought it would be a good idea... I hope some people respond. I will put it in the first post in list form.
My Feedback: (9)
WA
ORIGINAL: tele1974
DLE - 30 PROP DATA
<pre>
User Prop RPMs
</pre>
DLE - 30 PROP DATA
<pre>
User Prop RPMs
</pre>
Funny you say that, the plane I did my test on a segull 120 yak I ran the dle 30 with 19x8 prop revs 7450, I have now moved engine to a katana120
and have put my OS160 in the yak with 18x6 and 8550 revs, diffrents i found the dle300 had more low grunt and pull like no tomorrow with the yak
the os160 I would say performed 20% less IMO. now that is just my test other folks would find it diffrent i guess.
So my DLE30 runs a JXF 19x8 at 7450 and getting better each run.
regards awd
regards awd
OH
I could use the prop calculator for that but I'm not sure how it compares to real world data. According to the calculator the Mej 18x8 prop at 8500 rpms should do 18lbs of static thrust. That would be tasty on my 12 pound bird. I am sure it would be different airframe to airframe. For example if you have a Extra 260 with a big mouth of a cowl intake. Wouldn't that affect the thrust? We can throw the thrust numbers in if guys list it.
All numbers with MenzS wood prop, well balanced and drilled:
18x8 8,350 rpm
19x8 7,330 rpm
20x6 7,230 rpm
Using RCEXL LCD mini tachometer attached to the ignition sensor.
Regards
18x8 8,350 rpm
19x8 7,330 rpm
20x6 7,230 rpm
Regards
VA
cliff600 Zoar 18 X 10 7775
Plane flew really fast, but would not 3D well. I just crashed it yesterday, yip, sad, but I did not really like the plane. I want to get a Yak or 260 and put a 19 X 8 on it.
WA
ORIGINAL: MetallicaJunkie
based on the figures above,this engine compares to the os 160fx..... But id still take the DL30 over any comparable glow engine
I'm pretty close to sea level and don't think my 1.60 could make those numbers. Impressive.
1 Post
Hey all,
I am looking at getting one of these to replace a rather week 22cc engine I have on an Edge, what would be great is if you could include in your readings if these are on the stock muffler.
Xoar 20x6....anybody have the RPM????? Thanks Capt,n P.S. I think that will be a good prop for hover,climbout & slower landings.
good work
you might want to know my spe43 hit same rpm in respect to those props
what happens to ' no replacement for displacement' afterall they are only lawnmover motors []
ORIGINAL: jedijody
Xoar 18x8 - 7950, Xoar 18x10 - 7500, Xoar 20x8 - 6400, stock muffler, sea level
I have single bolt adapters now 3/8 thread drilled and taped for 10x32 spinner screw ,I will send you one.Hope there hubs are true.
BCCHI AMA 2500.
ORIGINAL: bcchi
7400-xoar 19x8 getting better all the time.
BCCHI AMA 2500.
ORIGINAL: jedijody
BCCHI AMA 2500.
