DLE 20cc Gasser! (Data & Links 1st Post)
Old 07-12-2013, 10:49 AM
  #6551
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
I don't remember who it was that posted it, or where, but pretty sure that headache is history.
ahicks is offline
Old 07-12-2013, 12:17 PM
  #6552
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just checked Tower - looks like they're giving mixed messages on the EI voltage. Looks like they're saying the old EI's require a voltage regulator for greater than 6v sources, but the newer EI's do not.
- 4.8 - 6V NiMH/NiCd, or 6.6V LiFe or 7.4V LiPo battery for ignition (separate receiver style pack can be used) (LiPo & LiFe requires voltage regulator)
- Ignition Battery: 4.8 min, max as marked on electronic ignition unit. If marked 6V max, BEC required if LiPo battery used. Newer ones may be marked 4.8V to 8.4V.
microdon2 is offline
Old 07-13-2013, 04:49 AM
  #6553
Indiomike
Indiomike's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Indiomike
It appears that new DLE20 engines being sold come with a new version ignition module. The newer version (A-02) is labeled to handle up to 8.4 volts, compared to 6.0 volts on the older version.
Some people have said that the newer version has also gotten rid of the timing curve (step) that the old version had. Can anyone verify that as a matter of fact. I haven't found anything from dlpower.com or dleengines that confirm that has happened.
A short while after I asked the above question, it occurred to me to call Tom Denny at Valleyview RC. Tom said the curve (step) has been removed from the new version module.
So this new version of ignition module for a DLE20 doesn't have the issues of the older version and can handle up to 8.4 volts. That's a very nice improvement.
Mike
Indiomike is offline
Old 07-18-2013, 07:52 PM
  #6554
bigtj10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Super photos; they really help! Did you double the firewall or did the plane come that way?
bigtj10 is offline
Old 07-18-2013, 09:25 PM
  #6555
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Indiomike
Quote:
ORIGINAL: Indiomike
Mike
The step in the timing curve was cured a little before they changed to voltage up to 8.4V. I bought 2 ignitions from Tom last fall, they have the new timing curve, but still only good for 4.8 - 6.0V.
Ernie Misner is offline
Old 07-20-2013, 06:16 PM
  #6556
Bonified Wingnut
Bonified Wingnut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need a 2 3/4" white spinner for my DLE on an Edge540....anybody know one that can handle a 16" prop?
Bonified Wingnut is offline
Old 07-20-2013, 09:20 PM
  #6557
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone know what size prop shaft thread the 20cc XYZ has? I'm trying to get a spinner for it. I think it is a different size than the DLE 20cc. Thanks a bunch!
Old 07-20-2013, 09:33 PM
  #6558
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, Ernie, Mike here. The early VVRC 20's had an odd-ball metric thread. The current versions like mine use the same thread as the DLE 20. Tom can tell you what the old thread was. (I don't remember at the moment)
rcguy59 is offline
Old 07-20-2013, 09:55 PM
  #6559
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Mike. It is a very fine (8mm I think) thread, very fine. What a blast to see you fly that 20cc warbird today!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-20-2013, 10:37 PM
  #6560
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a lot of fun to fly. Goes where you point it, does anything you ask of it. I let Tom Denney fly it today, and I don't think he wanted to hand the radio back to me! Here are some pics of it.
ID:	1902604   Click image for larger version
ID:	1902605   Click image for larger version
ID:	1902606   Click image for larger version
rcguy59 is offline
Old 07-20-2013, 10:43 PM
  #6561
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool pics Mike! Optional retracts?
Old 07-20-2013, 10:58 PM
  #6562
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The ARF came with mech. retracts, but I used a set of HobbyKing electric retracts and so far , they've been flawless. About 13 bucks for the pair. By the way, the airplane weighs 8lbs, 10oz. dry. APC 15-10 prop on the VVRC 20. Never tached it.
rcguy59 is offline
Old 07-20-2013, 11:00 PM
  #6563
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What a perfect combo!
Old 07-23-2013, 02:31 AM
  #6564
ShuttleAU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All
I have a throttle arm extension for the DLE 20 carb . It is a CNC version 16mm across and raises the arm about 12 mm
The only manufacturer ID seems to be RCB.
The hole at the end of the arm is threaded . Does anyone know the thread at the end of the arm is please?
BC
ShuttleAU is offline
Old 07-23-2013, 06:26 AM
  #6565
Indiomike
Indiomike's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ernie Misner
The prop shaft on the XYZ20 was 8mm x .075. The latest batch of engines now are 8mm x 1.00 which is the same as a DLE20 according to Tom Denny of VVRC.
Mike
Old 07-23-2013, 07:31 PM
  #6566
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the crankshaft tread info Mike. Another carb question - anyone know if the carb can be turned 180 degrees? Or if the throttle arm can be reversed in the carb? (on the DLE or XYZ (walbro). Just wondering, thanks.
Old 07-23-2013, 07:39 PM
  #6567
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ernie
I don;t know what you mean "reversing the throttle arm", but the whole carb can be turned 180 degrees on the DLE 20
w1nd6urfa is offline
Old 07-23-2013, 08:40 PM
  #6568
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. If you can reverse the whole carb, no need to try to pull the throttle shaft out and reverse that anyway.
Old 08-27-2013, 02:50 PM
  #6569
rapidus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
APC 18x6W 15.8 lbs thrust (7700trm) on my prox 260.
love this motor
rapidus is offline
Old 08-27-2013, 05:10 PM
  #6570
Scooterpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought a Vess 18X5.5....looking forward to see how it works on the AW Pro260
Scooterpilot is offline
Old 08-28-2013, 04:47 AM
  #6571
Howard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a spare DLE 30 ignition set and wondered if it has the same timing as the new DLE 20 ignition. I understand that it may require a regulated voltage, I am just curious about whether I can replace the DLE20 ignition with my spare DLE30 ignition. Thanks.
Howard
Howard is offline
Old 08-28-2013, 05:38 AM
  #6572
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wouldn't be my first choice, but if the price is right I'd sure use it?
The DLE 30 module has the same type "step" timing curve the infamous DLE 20 #4's has/had. The difference, the reason it wasn't so problematic, is that the step occurs at a much higher rpm - something around 42-4400 if my memory is working properly. Bottom line is it works fine. 99.999% of flyers would never suspect anything is different about them.
ahicks is offline
Old 09-02-2013, 06:05 AM
  #6573
OldRookie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am sure this question has been answered somewhere in this long thread, but the crappy search thread feature doesn't help much.
My question is " How does power of the the DLE 20 compare to the YS 120 FZ"?;
I am thinking about replacing my YS 120 With the DLE 20.
Thanks in advance,
Greg
OldRookie is offline
Old 09-02-2013, 07:58 AM
  #6574
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For power comparison, maybe check out what guys are using for props on each? 16x8 and 17x6 are both pretty commonly used on the DLE. They'll turn up into the 8500 (+/-) range, but one guy says his is working well on an APC 18x6W? I plan on trying that one soon.
ahicks is offline
Old 09-02-2013, 02:19 PM
  #6575
sparky4lawndart
sparky4lawndart's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You'll get a higher top end with the YS120 than a DLE20 in a dive. But the DLE20 has much more power to get you to speed
sparky4lawndart is offline
Display Modes
