***CUB BROTHERHOOD***
#1252
RE: ***CUB BROTHERHOOD***
hi malitape
they made at one time in the past material label coverite shrink, and super shrink. whcih I used a lot. in fact I had some from way back
<super shrink> which I just covered a telemaster 40 hobby lobby kit, also from way back.
don't know it these forms are currently available, have seen a listing on them lataly but they were great for covering, both were
unpainted and white.
thanks and happy flying
pt19 flyer
joe
pt19 flyer
joe
#1253
Pete that is the same stuff I used , It worked pretty good . It is easy because there is no painting involved and if you have dumb thumbs it is easy to repair...
#1254
My Feedback: (213)
Gentlemen, thanks for your replies. This is helpful info.
Joe, you mentioned that you had stock from some time ago that you recently used.
Does this material keep for extended time without going bad? Have a person at the
field with some rolls of coverite he had for years. little skeptical that it is still good.
What say you?
What say you?
#1255
I have some partial rolls of coverite that is 25 yrs old . I covered a Godfrey Super Stearman with it back then.. It is still fine.. I wish I had full rolls of it.. It is great stuff . Probably the best stuff I have ever used...If I could buy some full rolls I would snap it up in a hurry . The stuff I used was sort of white and you had to paint it ..It didn't take paint well...The paint wouldn't stick and would crack off in places but the covering sure was nice . I think the paint thing was just a matter of not knowing what I was doing..Not using the rite primer or something..
#1257
hi malitape
have had mine for probably 15-20 years. kinda gave up on building and got involve in ham radio
and other activities. lost interest here and am now back to model building. not much of an arf
flyer here. like to fly what I build. have many kits, some, at 82yrs old, I know I will never get there
on all.
as far as age on the coverite it looks and feels as good as it was at the time I bought it. can tell no
difference in feel or appearance and it went on and shrumk fine.
I say if it looks ok go for it. good stuff, I like it. don't know if it still made. think I had the big roll, don't
recall the length. still have some left for next model
pt19 flyer
joe
on all.
pt19 flyer
joe
#1258
hi malitape
a follow up here on the paint I never had a problem with the paint on the coverite. in the past I know I used
hobby poxy paints which is no longer available and and proibably others in the hobby line back then
on the current telemaster I used Dutch Boy fast drying spray enamel interior/exterior red 3730. painted about 2 months ago and still looks good. I did let it cure for about 3 weeks before use. give the dutch boy a try, appears to work great with the coverite
pt19 flyer
joe
pt19 flyer
joe
#1259
My Feedback: (213)
Thanks, Joe, will give it a try. My concern is if the adhesive is still working on an old roll
that has been laying around. Maybe I should use some Stix-It first so I have good bond?
#1265
malitape
the shrink and super shrink did not have the adhesive applied.
I used balsarite as a coating on the balsa which worked great.
stix-it would also work, I have never used it.
coat the balsa with the balsarite, let it dry and iron the fabric on.
also, on lapping the covering coat the edge of the fabric with the balsarite
and iron on. coat the section of fabric already attached and then do any add ons.
good luck and happy flying
pt19 flyer
joe
pt19 flyer
joe
#1269
NC
I would like to join the Cub Brotherhood as well as get some input on this 1/4 Sig that someone framed up and has just given to me. I wanted input on what to do with the fuse sides before I do my own thing. The plan is to convert this to and L-4. Trying to upload pic. [img][/img]
#1270
ORIGINAL: RCJones
#1271
Here is a link from J3 to L4. Both BUSA and Sig kits are referenced in the conversion. Good luck
http://www.rcuniverse.com/forum/m_92...tm.htm#1480703
#1272
AB, CANADA
I have recently aquired a 1/4 scale cub and would like to join the cub brotherhood.
I am not sure what make it is, but it does have a 105" (1 piece) wingspan.
The engine that is mounted in the plane is a German made Hans Hoernlein Profi 76 (12.65ccm)
with a 14 x 6 MAS prop.
I had to make some modifications to the original muffler as the engine is mounted inverted.
The factory pressure nipple was facing downward and a lot of exhaust oil went up into the pressure line.
As well the front of the muffler has a round factory hole in it that I had to plug with an M6 fine thread bolt.
Now there is enough pressure to the tank and the engine does not quit at 1/2 throttle due to fuel starvation.
I think that the engine has not run very much, because of the fuel problem.
This leads me to believe that the plane has not seen any flying action.
A few more tanks of fuel for run-in and she should be ready to feel the wind beneath her wings.
If anyone can direct me to what the make of this model is, it would be much appreciated.
I need some info on the C.G. measurements before flight time.
I have looked at quite a few posts and came up with SIG, but they all seem to have two piece wings. Mine is a one piece wing.
Andreas
Happy building & flying.
Andreas
#1274
28% MAC is a good place to start when balancing a Cub.
You may find you can move the balance back after you get a flight or town under your belt. When the balance is correct they should just float in on landing.
Later!!
Anthony
Later!!
Anthony
#1275
AB, CANADA
Thanks for the info rafeeki and Anthony.
Much appreciated.
I will measure it out on the weekend and see where she sits.
Luckily the Mean Aerodynamic Chord measurement is easy on the Cub wings.
No swept back wings. LOL
Basic rectangle measuring. :-)
Andreas
Much appreciated.
Andreas
