Where to buy prop for old k&B 3.5 outboard?
I have an old K&B 3.5 nitro outboard motor with a broken prop! Where can I find a prop for this boat? It is a metal prop with p/n numbers or size on it. What measurements do I need to find another prop? How do I determine if it is left hand or right? Thanks in advance. Ricky
RE: Where to buy prop for old k&B 3.5 outboard?
For an older motor, use an Octura X437/3 or X438. A Prather 215 will work also. One site that sells them is www.funrcboats.com plus there is an area on the site that shows you how to sharpen and balance the prop.
