I Have A.....
WI
RE: I Have A.....
well you can always get another tranny and make a 4x4 pede with the right motors,locking the diffs you would be able to crawl
here is just a few pics of mine when it was still assembled the chasis is custom built and it had 4 wheel sterring using stock traxxas parts from two stampede trucks
RE: I Have A.....
you need 4wd, ground clearance, which the rustler doesnt have. And to have a good rock crawler, you need solid axles!
Oh yeah, a 4-link suspension!
RE: I Have A.....
i totally encourage you to try this, that is what rock crawling is all about, custom[sm=49_49.gif]
You basically just need a good idea, and a chassis that will hold everything together. I have seen some really interesting things done before. Good luck, and keep us posted on what is going to happen!!
RE: I Have A.....
will do. I have a milling mechine at work so thats going to come in handy when i go to make my chassis and my diff mounts and so on i hope it comes out good well at least works right anyways
RE: I Have A.....
i have the chassis milled up and now i'm just trying to think of a way to to the axles and wheels you know but it's comming along but at a slow pase
ON, CANADA
RE: I Have A.....
To make 4 link you could replace the shocks with turnbuckles to lock them in the down position, that will give you good diff clearance. Then all you have to do is figure out some suspension geometry and make the links.
RE: I Have A.....
I do I just have to get buliding now. I hope I have it done by the spring. Hey whats a good turn motor to use for this? i have a spare 27 turn stock motor will that work ok
