TXT-1 plowing snow *with video*
OH
Video
http://www.youtube.com/watch?v=Z649j6ejppk
It was too easy to plow the 1.5" of snow... It could easily handle a 3" snowfall
OH
RE: TXT-1 plowing snow *with video*
The extra weight from the bigger truck and 2 batteries in parallel with the 4wd helps a lot. It would be more difficult with a smaller 2wd ike your stampede.
Thanks!
It goes much faster when I'm not trying to record and plow at the same time. I can do the driveway in about 10 min....I only used 2500mah out of 8400mah available to do it.
ORIGINAL: 86waterpumper
That is cool, and works surprisingly well! How long does it take to do the whole drive?
ON, CANADA
that txt-1 is serious!, i'd put fule tubing down or sumthing on the bottom of the plow then it wouldnt make that horrible rubbing sound, dont no if that would work as well tho
RI
ORIGINAL: Redvanmafia
FL
That works awesome!!! I always figured those plows were kind of a joke and just for show. Who knew they actually worked! As for the grinding noise from the plow, have you ever heard the noises a full scale truck with a plow makes? That grinding noise is nothing!
Your TXT is sick.
I'd love to see what the neighbors say when they look out their window and see a tiny truck plowing the driveway haha!
OH
Thanks for the compliments!
The weather man is saying 6-10" of snow starting today and ending tomorrow afternoon. [X(]
