Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Reload this Page >
Bro rc Surfer Custom Boards
RC Boats General Discussion Discuss general rc boating topics here.
View Poll Results: Would you like to see a Bro******** e-book published
Yes - that would be great !
17
73.91%
Not particularly
6
26.09%
Voters: 23. You may not vote on this poll
Old 06-27-2013, 11:11 AM
  #276
YPC
YPC's Avatar
Default RE: Bro ********'s Custom Boards
Howzit BC.......thinking is a 'good thing'.....trying to get 'my kids' into the habit....LOL
I guess we could use your 'sexual line of thought' as a working example.....but it could get messy...LOL.....this part has to be kept 'clean'
I'll try to chose my words carefully so that your mind does not wonder....LOL
As you say - when the epoxy is injected into the cavity, the air simply escapes past the syringe nozzle ( its not an air tight fit) although the fit should be snug enough not to allow any epoxy to seep past, so as to be pressurized into the open foam cell surrounds within the cavity for that much needed anchoring. Usually - when you withdraw the the syringe nozzle - some epoxy will expand out of the cavity due to it being under pressure, this excess you simply wipe away......are you still thinking 'technically'.....LOL
Remember !......to turn the threaded studs into the cavity as you position them - as if you were turning them into a threaded nut of sorts. If you simply push it down into the cavity, you will force most all of the epoxy out, not get epoxy into the actual thread of the stud.... resulting a poor anchoring.
I am enjoying the 4cell set up.....just need my metal props to arrive.....I blow the plastic prop blades off most every session....
Looking forward to mastering the 'Carving 360'.....nice move for th e********.....both front hand and back hand.....
Bro'
Old 06-27-2013, 11:35 AM
  #277
YPC
YPC's Avatar
Drive shaft housing and Stuffing Tube ...........
I use a 10 mm OD / 6 mm ID stainless steel tube end for the drive shaft housing. The stuffing tube is a 6 mm OD brass tube..( epoxied into the S/S)...in which I run 4 mm ID brass bush's either end - for the 4 mm stainless steel solid shaft to run in....
It is 'important' to ensure that the stuffing tube and drive shaft assembly is 100 % true before setting up the motor/mount plate and drive shaft housing for final epoxying.
I use the live center on my lather as a pointer to straighten the assembly out.
The Prop end brass bush is easily removable for cleaning/ greasing.....
The stuffing tube can be reamed out of the Stainless Steel Tube to be replaced if ever need be.
ID:	1895578   Click image for larger version
ID:	1895579   Click image for larger version
ID:	1895580   Click image for larger version
ID:	1895581   Click image for larger version
ID:	1895582   Click image for larger version
ID:	1895583   Click image for larger version
ID:	1895584   Click image for larger version
Old 06-27-2013, 11:05 PM
  #278
YPC
YPC's Avatar
Awesome way to start the day !
Having a 'Power Breakfast' with my youngest daughter 'Cassidy'.....sure will be energised to get some extra work done this morning....LOL
ID:	1895721   Click image for larger version
ID:	1895722   Click image for larger version
Old 06-28-2013, 03:34 AM
  #279
bearcave
Hi Bro
Great info with the epoxy injection thanks heaps... only thought of sex things when it got messy... lol
btw i just checked out the mauinow link on your post 271.... checked out the included links as well... interesting stuff...
KS does rip hey even though he snaked/dropped in on the longer boarder but thats how it is and maybe the other guy should have played the game better and...
Anyway gotta go... all the best Bro... always watchin please keep up the nice work surfin and family wise..... bc
Old 06-28-2013, 07:12 AM
  #280
YPC
YPC's Avatar
Man !..... those Cookies really worked for me....I better check her 'ingredients'.......I have been charging all day.......
Finished up fitting all the hardware in both boards - and gave the hulls their final 'Gloss Coat'........to be sanded and polished.
This final layer of resin is great for sealing off and supporting the Rudder tube and water pick up/ outlet tubes..... rudder tube in pic will be ground down once resin has cured. The resin floated around the base of the tube seals it well and forms a resin rim that adds much required strength to the set up.....
Just need to spend some time with the Bro's....finish off a few touches hear and their....and then we are done....
These boards are going with 'no electrics'
Have great weekend all......I'm hoping for some good surf.......
ID:	1895786   Click image for larger version
ID:	1895787   Click image for larger version
Old 06-28-2013, 12:35 PM
  #281
YPC
YPC's Avatar
Componenets..........
A few guys have mailed me, inquiring about availability of various hardware components.
I am working on putting together a list of hardware :
Bi- Fin (with a choice of post diameter) - Servo tray - 25 mm center to center motor mount plate (to fit into the pod) - Stuffing tube and drive shaft assembly ( 250 mm long - easily trimmed to shorter length) - plastic knurled nuts - motor to shaft couplings .......
The last two pictures show the bush / bush housing fit - the outward tapered rim of the drive shaft bush fits into the beveled cut away with the housing - preventing the bush from traveling up the tube. This is a well tested bushing system, being used in performance rc boating for umpteen years - very easy maintenance and bush replacement.
ID:	1895881   Click image for larger version
ID:	1895882   Click image for larger version
ID:	1895883   Click image for larger version
ID:	1895884   Click image for larger version
ID:	1895885   Click image for larger version
ID:	1895886   Click image for larger version
ID:	1895887   Click image for larger version
ID:	1895889   Click image for larger version
Old 06-29-2013, 08:38 AM
  #282
YPC
YPC's Avatar
finishing the Bro' twins..........How to tell them apart....one will get an 'Orange' rash vest ......and the other a 'Lime' rash vest....
I coat the inside of the hatch cover white...gives it an opaque look on the outside and prevents seeing all the running gear through it.
ID:	1896084   Click image for larger version
ID:	1896085   Click image for larger version
ID:	1896086   Click image for larger version
ID:	1896087   Click image for larger version
ID:	1896088   Click image for larger version
ID:	1896089   Click image for larger version
ID:	1896090   Click image for larger version
Old 06-29-2013, 12:32 PM
  #283
YPC
YPC's Avatar
Our Seamstress !............besides being the camera 'lady'...
Lisa-Marie has got this process down to a 'T'..having to use both the over-locker and sewing machine, producing fine snug fitting 'miniature' rash vests.....The 'rash vest' has become a 'standard' issue for Bro' - it definitely gives the Bro 'figure' better 3D dimension and proportion...&...touch of realism - as well as the bright Lycra material colors helping to make Bro more visible in the surf......
ID:	1896139   Click image for larger version
ID:	1896140   Click image for larger version
ID:	1896141   Click image for larger version
Old 06-30-2013, 03:22 AM
  #284
YPC
YPC's Avatar
As my folks always advised me...... " get a firm footing and your head properly screwed on".........LOL
.....same advise goes for Bro'...make sure you "bond those feet on well and glue that head on properly"....LOL...the dude needs 'integrity' !!!
Including his rash vest - Bro is weighing in at 150 grams (5 ounces)
I use a 'slow cure' epoxy (overnight) - tape up area on hatch cover- roughen up and thoroughly de -grease both surfaces - coat both surfaces with epoxy - press surfaces together ensuring a complete bond (oose out all around) - remove excess - remove masking tape - leave to cure.....
ID:	1896401   Click image for larger version
ID:	1896402   Click image for larger version
ID:	1896403   Click image for larger version
ID:	1896404   Click image for larger version
ID:	1896405   Click image for larger version
ID:	1896406   Click image for larger version
ID:	1896407   Click image for larger version
Old 06-30-2013, 03:28 AM
  #285
YPC
YPC's Avatar
Bro' on a Kyhoso Board...........certainly has a nice proportion......itsFishi ran one of the original Bro's on his modified NQD some time back with good results......
Price = US$ 100 including the rash vest ......shipping would be around $ 20 by air.......'bond on' feet bases.
ID:	1896410   Click image for larger version
ID:	1896411   Click image for larger version
Old 07-01-2013, 09:03 AM
  #286
YPC
YPC's Avatar
Sanding down the Final Gloss Coat....
When the final Layer of sanding resin has cured completely .....it requires a few sanding process's to bring out the 'gloss finish'
A good way to remove the resin lip formed around the rail, which is left behind from the masking tape skirt, is to scrape the resin lip away with a blade.....if you try sanding it away, you will run the risk of sanding through the resin layers, hitting the cloth.....which will mean you will have to 'start the layer over'
Once the lip has been removed all around the rails...its time to break out the 'water paper'.....with water /touch of liquid soap - I sand the entire board down methodically with grit # 300 - 400 - 600 - 800 -1200 .....paying special attention 'never to sand through'....
A added a picture of the rudder tube - to show the epoxy core covered by the resin layer.....
ID:	1896728   Click image for larger version
ID:	1896729   Click image for larger version
ID:	1896730   Click image for larger version
Old 07-01-2013, 09:11 AM
  #287
YPC
YPC's Avatar
Polished finish ....'Gloss Coat'.....
When the sanding process is complete.....Rinse and dry the board down......
First I hand buff the entire board with a Burnishing paste......then I give it a wax polish to bring out the luster...
It takes quite a bit of elbow grease to realise a great shine.....but I love the authentic glass over foam finish.....I use a UV preventer in my resin so the cream foam color remains stable
ID:	1896734   Click image for larger version
ID:	1896735   Click image for larger version
ID:	1896736   Click image for larger version
ID:	1896737   Click image for larger version
Old 07-01-2013, 09:34 AM
  #288
YPC
YPC's Avatar
Saying Good - Bye !...........these fellers are off to France !....we named them...Juan & Pierre
This order was ordered 'without the electrics'....I do however set each board up with a motor - to make absolutely sure that all fits 100%....
Once the clients receive the boards, it will be as simple ABC for them to install their motor - ESC - Servo - water cooling pipes.....prop and battery...
What was impressive to me - the difference between the two boards 'in weight' was only 7 grams........amazing........when all the electrics and battery is installed, the board will weigh between 2 & 2.2 kg's depending on battery size.....
Last 'board' picture is the housing with all the electrics as it should be when installed....( these boards can run 3s or 4s batteries)
Well !..as you can see....plenty of work and detail goes into making these little guys what they are and what they are capable of doing....its been great sharing this build with all......hope you have all enjoyed the process with me....always feel free to post or PM me should you need any questions answered.
Next Bro ******** build is for a client in Mexico !.....Ombre' Bro'
I better get started !!!......just love it !
The complete float'er rcsurf board with Bro surfer - as seen in the pictures (without any electrics) Cost = US$ 650-oo
With all the electrics ( excluding radio and batteries) Cost = US$ 950
ID:	1896740   Click image for larger version
ID:	1896741   Click image for larger version
ID:	1896742   Click image for larger version
ID:	1896743   Click image for larger version
ID:	1896744   Click image for larger version
ID:	1896745   Click image for larger version
ID:	1896746   Click image for larger version
Old 07-01-2013, 11:12 AM
  #289
YPC
YPC's Avatar
I reckon Bro has some serious competition.... John John Florence going for Big Air Rotation moves ! ...must have been watching our rcSurfing vids.....LOL
Surfing style and criteria is certainly 'changing' its tune.....One 'big XXX move'.....can count for way more than a long traditional 'power ride'
For free style surfers - I guess its a case of 'what ever floats your board'.... what ever you enjoy......Personally.....I love the 'Big Moves' = it's 'all or nothing' !
http://www.youtube.com/watch?v=V_p9z6rgDzg
Old 07-01-2013, 11:28 AM
  #290
YPC
YPC's Avatar
A classic video....sharing our SA surf.( mostly of Cape Town )...our great talent ....and awesome Vibe.....!!!
http://www.youtube.com/watch?v=UF6hjMYnlAI
Old 07-02-2013, 12:51 AM
  #291
YPC
YPC's Avatar
No rest for the Wicked !.......need to get a boat order out this week for the US'......as well as'......get the new float'er going for Mexico'
Its also school recess....so the boy'z have their projects......
Nic is up-sizing a floater to a full scale board for himself to surf ......&.......Jensen is shaping a slightly smaller float'er for his 2s electrics that he has....this little guy has an amazing eye for symmetry.....
ID:	1896954   Click image for larger version
ID:	1896955   Click image for larger version
ID:	1896956   Click image for larger version
Old 07-02-2013, 11:50 AM
  #292
YPC
YPC's Avatar
Something off the subject !............for interest sake......perhaps 'nice to know'
Something perhaps interesting for those who don't know....another one of my passions and YPC products is the 1/4 scale F1 Outboard and Inboard rc racing boat. I have raced - designed / developed and manufactured these boats and their hardware for many many years and can proudly say that I have boats racing on most all continents around the world.
I still produce these boats and products for clients (the green one is going to the US) - however I stopped any further Gas Class development at the end of 2011, due to the continued restrictions being placed on them due to noise and exhaust immisions pollution controls, severely limiting the usage.....simply put....its just not economically viable....
I am working on developing ' HVFE ( high voltage fast electric) set ups......the boat design will remain much the same....just the drives will change. Developing the Bro ******** has been a great learning curve for this F1 electric development .....and I am quite exited visualizing what we will be presenting in 2014 in the line of HVFE F1's
Enjoy watching one of our local club races ( Orange boat is me) - all the boats racing are YPC boats
http://www.youtube.com/watch?v=xSpFF4fcWrQ
ID:	1897055   Click image for larger version
ID:	1897056   Click image for larger version
ID:	1897057   Click image for larger version
ID:	1897058   Click image for larger version
ID:	1897059   Click image for larger version
ID:	1897060   Click image for larger version
ID:	1897061   Click image for larger version
Old 07-03-2013, 05:44 AM
  #293
bearcave
hey Bro
Nice links to the real surfers....
BTW... If your attractive camera girl wife mother seamstress and obviously full time job looking after you... lol... would be interested in makin a red vest for a brosurfer to ride my yet to be finished board i'm keen to buy...
Unfortunately he has to be shipped to Australia... and no worries i'm sure you don't want your dude's on any old boat but hey bro my board is gunna happen i just need more time but makin a dude will put me into next year... Kyosho dude or Lisa will fill the void on the ply decks while testing but rekon your dude would be best fit on the glass deck..
Anyway just gettin in my dibs maybe i pm you or visit the bro site...
gotta go just sayin... bc
Old 07-03-2013, 09:18 AM
  #294
YPC
YPC's Avatar
Howzit BC....
Lisa - Marie reckons 'Red is no problem'...shipping to OZ even less of a problem....Shipping would cost around US$ 15 by air.....let us know when you would like a Bro.
Maybe....having Bro hanging around 'drinking all your beer in the cave' whilst he waits for his board to be finished will be a good motivator for you to 'get it done'.....LOL
Got started on the Ombre' Bro for Mexico to- day.....
ID:	1897274   Click image for larger version
Old 07-03-2013, 11:17 PM
  #295
YPC
YPC's Avatar
Gees !......what a way to 'Start the Day'........as they say ....a man cant live on 'food alone'.......LOL
Hey BC.....looks like their are going to be a few Bro's hanging out on the OZZY beaches....Dread just asked me to send him a Bro for his Ol Mate..
Old 07-04-2013, 03:00 AM
  #296
YPC
YPC's Avatar
Filled with a healthy breakfast .....layered with Love....got the Ombre' Bro shaping' complete, as well as the hull lamination...
Working with the board fixed to the 'stand' is an absolute treat. The table it is on , is on castors, so I can rotate it around to set the correct light on the board when comparing rail shapes etc. as well as great when glassing the board....to be able to rotate the table around......
ID:	1897484   Click image for larger version
ID:	1897485   Click image for larger version
ID:	1897486   Click image for larger version
ID:	1897487   Click image for larger version
ID:	1897488   Click image for larger version
ID:	1897489   Click image for larger version
ID:	1897490   Click image for larger version
ID:	1897492   Click image for larger version
ID:	1897493   Click image for larger version
Old 07-04-2013, 03:19 AM
  #297
bearcave
Hey Bro.
Some in Oz are time poor especialy when fightin off them rabid Koala's eatin our scrambled eggs on toast, giant possums eatin all the cats and dogs and then add in the hungry girlyfriends wanting more and more... wish the little munchers would eat other beasts like employers wantin more and more too and...
Anyway might go a driveshaft and some of them scrambled eggs on toast too... then again bugger the eggs they will be off by the time they get here.. don't suppose Lisa-Marie would like to visit too... oops that was naughty, you guys would be useless without her, doubt she would want to holiday in a cave with a bear either.... LOL
Anyway enough fun... am using 4mm shafts with threaded props atm except for kyosho. Like your setup but atm don't have a lathe to cut down to 1/8th for the props btw red and yellow seem to be the best colours for me to see so until i paint the board the rider will be the key to see.
Don't see any probs with a flexy bro drinkin my beer either... no way he will beat me to the fridge...  lol
Old 07-04-2013, 03:34 AM
  #298
YPC
YPC's Avatar
BC......You are 'crazy'......you have to get out of that cave 'more often'....I understood 'some of that'.....LOL
PM me your e-mail address when you would like to order a Bro Surfer - Lisa-Marie will then send you a PayPal invoice......No ! she cant hand deliver it.....LOL
Old 07-04-2013, 03:48 AM
  #299
bearcave
Haha Bro knew you would get a laugh....
Computer has a malfunction with emails atm, can get em but can't send em... no wonder i'm annoying everyone via websites... getting some time soon to hopefully fix the prob.
btw like the board stand, my cupboard worked wonders using similar screw down system but only needed one self tapper top and bottom into the stringer
All the best will pm you for an order soon as email fixed... paypal is good btw.... bc
Old 07-05-2013, 01:27 AM
  #300
YPC
YPC's Avatar
Glassing Ombre Bro's deck........
Two layers of cloth....whetted out with polyester resin...once this has cured, I will apply a filler coat to the deck which fills in the cloth weave and smooths out the wrap cloth irregularities around the rails....... 'before I turn the board over to fit/glass the Pod on...
ID:	1897674   Click image for larger version
ID:	1897675   Click image for larger version
ID:	1897676   Click image for larger version
