Need Speedometer for RC car or something to record max speed
I'm trying to record the max speed (mph) of how fast my rc car is going. I have an iphone I tried every app I could find and none of them are giving me accurate readings, some not recording any speed at all. I bought a Garmin Forerunner 201 it looks like it's tracking the speed on the device while it's running because when it slows down and I catch up to it I can see the MPH decreasing. However when I check the history, it always gives me the same stats like 3 mph one time I got 10 mph and there's no way my jato is going 3 that slow. I guess it could be the device itself since I bought it used but, not sure if I should buy the same thing again or buy a different device.
What can I use? I probably need a GPS device that will record max speed. I don't want to install telemetry or anything that has to be actually installed into the vehicle and plugged into the receiver etc. I have some other things that I need to measure the speed on that are not hobby grade rc cars.
Any suggestions?
Any suggestions?
RE: Need Speedometer for RC car or something to record max speed
thought about that too but, how will I be able to use the radar gun while I'm driving the car? i'm doing this at my shop and i'm the only person here.
i'm thinking about getting it just to try it but, would like to hear some other suggestions first.
are you sure the garmin is in the right setting as i have the 301 and it took a while to get it right. on mine i can set 3 things like top speed average speed and distance. and i have to press start before the run. also if you plug it into your PC you can see what speeds you were doing. and you can overlay you run onto google maps.
ORIGINAL: turok007
Or if you have an iphone or any android device, there are a multitude of apps (some free) that will give you a lot more information than most RC telemetry systems, and more accurate too, since it's accelerometer AND GPS based.
OH
ORIGINAL: Foxy
FL
I use a stalker Pro Radar gun (it's for sale) and when I am alone, I just put it on a tripod. The gun has a max speed hold feature so it will hold it's highest speed and display until you clear. Iused to use it back in the day to radar Jet Skis for race applications. Now we just set it up at the end of the runway and let the hot rodders make high speed passes at it. If anyone is interested in purchasing it, please PM me as Ihave no use for it anymore. This is the same one police used before lasers became all the rage.
ORIGINAL: Muttdog
ORIGINAL: Muttdog
However, could you please let me know which kind of tripod you use? Then maybe I can get one of the cheap bushnell radar guns and set that up on a tripod.
Thanks!
well the tip about the tripod was good i started doing some research and ended up coming across this:
it's a little more than what i wanted to spend but, looks like it would work great for me and the reviews are good. i wanted to make some youtube videos and at first i was just going to take a picture of a gps unit on the car but, now I can just have that display setup and while i'm driving the car, i'll be able to record the speed/display in the video.
ORIGINAL: ejc34710
He said in his first post he already tried all the apps he could find with no success.
ORIGINAL: Foxy
OP, you know you need to setup and callibrate the apps, right? Anyway, a speed gun is probably the better solution.
just saying a radar gun is good but after a while you might want a speed tracker with GPS like the phone app or garmin.
1 Post
I use a garmin foretrex 301 for my large scale gas boats. It works great, is nice and compact, and will connect to your PC to download your information. The nice thing about downloading runs is you can see what speed you are traveling at any point, not just the maximum and average speeds recorded.
ORIGINAL: Foxy
I've used Dynolicious for iphone and OBD Torque for Android, they work well in my 1:1.
ORIGINAL: ejc34710
ORIGINAL: Foxy
Well I'm really looking forward to the radar gun, and I'll probably go ahead and get the Garmin 301 as well if I can find a good deal on a used, if I can get it for $50 so I'll do it.
ORIGINAL: Foxy
ORIGINAL: ejc34710
ORIGINAL: Foxy
Hey those apps are cool, Does the OBD one use GPS as well as wheel speed? I'm assuming u are using a dongle on the ODB II plug? What's the range on the Bluetooth dongle like?
Bluetooth range is standard at 8-11m.
I always found dynolicious (this was a while ago, a couple years) to be the preferred choice as it used almost exclusively accelerometer data, which I feel has the potential to be the most accurate assuming running on a perfectly flat surface.
To be honest, I haven't used ODB Torque for much but diagnostic checks, I borrowed a dongle from someone else, still haven't decided what I'm going to use the app for to be honest, but I was planning on finding an RC use for it.
Ahhh cool. Cheers
My wife's car has the diagnostic plug in the engine bay so that's why I was curious about the range.
I'm gonna buy dynolicious. Thanks for the sharing
We have developed this product that is being extended to provide speedometer/odometer information for RC cars. Check it out on kickstarter: http://www.kickstarter.com/projects/...-is-your-train (or RC Car)
My Feedback: (49)
