1/5 scall
1/5 scall
Sorry for my questions I am pretty new in this scale hobby
can i get same guide \proses what the problem and Symptom for each problem
so its can help me to find more fast the problem
(the think that i know fuel:1L FUEL\25 OIL ;SPARK TO CHECK )
RE: 1/5 scall
this is i know i need
same guide \proses what the problem and Symptom for each problem(same guide to troubleshooting)
RE: 1/5 scall
When you say it's hard to start, do you mean that it takes a lot of pulls on the starter? When it starts, does it run ok until you stop, or does it stop running sometimes?
RE: 1/5 scall
Hi fgbaja
I didnt run my car for years and found out my needle settings were much too rich for some reason.
What I did was unplug the fuel inlet tube into carb. then tried to start as normal. it fired up for a second.
That told me it was fuel/air mixture problem.
I then replaced the fuel inlet and fiddled with the needles until I got it running again.
Cant guarantee it will work, but it worked for me.
Best of luck,
Skinned knuckles are no fun!
Best of luck,
