RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Giant Scale Cars (http://www.rcuniverse.com/forum/rc-giant-scale-cars-234/)
-   -   Is the HPI Baja 5b Fast? (http://www.rcuniverse.com/forum/rc-giant-scale-cars-234/4358942-hpi-baja-5b-fast.html)
Capital Bulldogs 06-06-2006 08:29 AM
I know its not meant to be a street racer, but I have always like my RC cars to be quick thus I usually end up switching out engines adding 2 speeds etc, and so far from the videos that I have seen and the comments I have read, it appears that Baja is slow. Can anyone estimate about how fast the stock baja is? 35MPH? And if I wanted more speed is there anything currently available to do upgrade outside getting a bigger motor?
Doohan 06-06-2006 08:37 AM
RE: Is the HPI Baja 5b Fast?
It's slow, and the gearing is too short.
I think it runs 17 pinion/ 57 spur....should be about a 20/22 to 48/46.
The CY 23cc is a pig, the best thing to do is stick a 26cc or 29cc Zenoah in it.
My FG Monster Truck does 90 KPH...about 55 MPH with a zenoah.
Timmahh 06-06-2006 08:38 AM
posted speeds are about 29mph out of the box, knock off the exhaust stinger and your at 39mph out of the box, beef up the engine/ stuffed crank, shaved head, oversized piston and 50s just around the corner. by pig do you mean weight wise or gas consumption wise, cuz im getting about an hr per tank. the thing is heavy, but my Bergonzoni is just as heavey if not a bit more.
Timmahh
TurtleRacing 06-06-2006 08:39 AM
Only 29mph out of the box. If you take the extension tube off, extreme RC says you get 10 more mph. Then there's the X-Can, there are also several tuned pipes in the works. That's it for the moment other then the fact there are endless options for the motor.
radio_controlled_mad 06-06-2006 09:25 AM
not sure removing the pipe off the baffle box adds 10mph,a top of the range tuned pipe wont even add that,,,and thats all the stock can is - a baffle box with a metal tube (not a stinger) to deflect the smoke/unburnt oil,,,,fg monster models have longer exit pipes on there stock cans (which are the same) and have yet to read a post about the increase or lack of peformance removing these give - it would be cheaper than spending £150 on a samba,,,i think its more to do with gearing
TurtleRacing 06-06-2006 09:33 AM
Well the info comes from somebody with a radar gun, so whatever. I also don't see why it's so hard to understand restricting exhaust flow slows it down? Why also does everything go back to FG?? Does the FG use the same size tube??
Timmahh 06-06-2006 09:52 AM
the speed increase by removing the stock stinger has been noted by many owners as viable already. not being contradictory here. this has been posted on and verified at the HPI BAJA forum buy current owners.
hth
Timmahh
radio_controlled_mad 06-06-2006 09:59 AM
1 Attachment(s)
when you remove the extension pipe it will make it louder which generaly gives you the impression your going fasters when your not,the stock can is all it is "stock can" there is no restriction to hold back the engine.it is not a stinger - stingers are used on top-end tuned pipes and run into the $$$hundreds,the can has a metal exit pipe not a stinger.if it was that simple to get a extra 10mph out any make of stock engine then it would be commen place...most if not all get there models from stock with the same baffle box and some with longer extension pipes
samba tuned pipe with "stinger" (stingers add to the engine not decrease it)
TurtleRacing 06-06-2006 10:14 AM
Trust me Timmahh, he knows way more then any radar gun & that'll never change. I'm sure extreme Rc & everybody else that checked it was going on sound alone & there's no way a long piece of small diameter tubing can restrict a motor!
kinggeordie 06-06-2006 11:18 AM
yep totaly agree with rcm like a real exhaust remove a bit theres not alot of pressure sounds louder thats all - exhausts are normally made in a specific way even tuned pipes -remove bits and it would surely drop the performance
Tigger N. Bennie 06-06-2006 11:29 AM
ORIGINAL: Capital Bulldogs
If you want more speed, have the engine modified (just like any other engine) or change out the gearing if and when optional gears become available. If you really want speed, then go electric. For that matter H.A.R.M. has a brushless 1/5th scale, but if you run some 8000mh 5-cell lipos, be prepared to spend some big bucks.
ORIGINAL: Doohan
I'd say the gearing needed depends on the track, just like any other R/C. In my opinion, the Baja5B had plenty of speed for the track I ran it on. And yes, the pinion is a 17T and the spur a 57T.
http://image.rcuniverse.com/forum/up...16/Ki19579.jpg
ORIGINAL: TurtleRacing
I could probably hook up the tach on my Nomadio Sensor, but I figure that members would just then argue that my Sensor is off.
radio_controlled_mad 06-06-2006 11:39 AM
leaving the hpi v fg b/s aside...
removing the exit pipe on a stock can on say a fg monster which has the same engine,same can & same size exit pipe as the baja will not give a 10mph increase...thats all it is "a can",,,top end pipes only add 1bhp - porting adds 1bhp,removing a metal pipe does not add 1bhp
i think it has more to do with the hpi17/57 gearing compared with fg18/46 or 16/48 - could be wrong as im not sure how many teeth the hpi dif has.
TurtleRacing 06-06-2006 12:04 PM
Ok, the radar gun lies & so does the mag, I believe you!
rbgerrish 06-06-2006 12:10 PM
Xtreme RC Magazine Clocked the Baja at 39.8 mph stock.
I like mine!
http://www.orcrc.com/outings/PDRM4747.JPG
kinggeordie 06-06-2006 12:14 PM
i think what we need are some dyno results
as far as the pipe is concerned if that was the case we would be doing it with the fg stock pipe why spent 100 -150 on a performance pipe when all you have to do is remove the pipe of the stock and hey bisto its a fully tuned performance exhaust
radio_controlled_mad 06-06-2006 12:15 PM
well theres a great tip for all those guys with a stock cy or zen which has the same stock can and exist pipe (the make of car is irelivent) just remove the exit pipe,10mph increase without spending a fortune on modding the engine....instant 25% power increase
kinggeordie 06-06-2006 12:19 PM
lol maybe if we remove the exhaust it might do 100mph
Tigger N. Bennie 06-06-2006 12:20 PM
ORIGINAL: radio_controlled_mad
Well thanks for that tip. A little late though since I already did it.
ORIGINAL: rbgerrish
I like mine!
I like it too though I would have waited for the clear body. I also like the looks of the HPI Baja 5B better than the FG Marder. Consequently, I don't even care if the Baja5B is slower, especially since I realize that the Baja5B is a RTR and many RTRs are a little slower out of the box. I also figure that if I wanted to drop in a Zenoah, I could do that as well if I wanted to and the price difference wouldn't be all that great between the two R/Cs. Of course, a gearing change would probably be cheaper and easier--depending on the track since it is also not all about speed, but control as well as someone mentioned.
D0G 06-06-2006 12:23 PM
I like mine!
That body is WAY nicer then the Purple and yellow one I have been seeing. IMO
Tigger N. Bennie 06-06-2006 12:29 PM
ORIGINAL: D0G
The chassis may be purple, but not the body.
http://image.rcuniverse.com/forum/up...16/Da83179.jpg
hellya 06-06-2006 12:30 PM
Show me the video including the numbers on the gun and the calibration of the radar gun
Tell the person driving not to hold back on the trigger finger for either vehicle
FG extensions pipie is the same tube as the HPI......no way your getting 10 mph faster removing it.....I dont even think the jet pro gives you 10 mph more:)
D0G 06-06-2006 12:32 PM
LoL, did you not see the IMO....doesnt that wave the right of anyone to bash me??? :D
Haha, anyhow...you got what I meant didnt you..lol..
kinggeordie 06-06-2006 12:33 PM
ORIGINAL: hellya
Telll the person driving not to hold back on the trigger finger for either vehicle
FG exhaust is the same tube say the HPI......no way your getting 10 mph faster removing it.....I dont even think the jet pro give you 10 mph more:)
yep totaly agree if the gun is not calibrated it would be miles out - and belive me i used to work with many instruments that had to calibrated every time before we went out
Tigger N. Bennie 06-06-2006 12:33 PM
Why don't you just try to find the magazines that have been mentioned? Myself, I haven't read them either but I'm also not arguing abut it either since if I want a fast R/C car, it is not going to be a large scale gasoline/oil mix R/C. Heck, I'm just trying to keep the peace in yet another petty disagreement.
Tigger N. Bennie 06-06-2006 12:39 PM
ORIGINAL: D0G
I didn't bash you. I also only got what I think you may have meant. And on this forum of petty bickering, it appears that everyone must have a photo and a sworn affidavit to believe anything that anyone else writes or posts.
