My scale 1/5 F-16 B
#454
RE: My scale 1/5 F-16 B
Yess, the first molds are ready and popt open . I am happy with the result, all the tiny details are there and after a good clean up ready to go.
#456
COOL !!!!
No words my friend. Very good job, congrats.
Regards from Spain.
Carlos Márquez
______________________________
www.cmjets.blogspot.com
Regards from Spain.
Carlos Márquez
#461
Hi Thomas, yep a mix of chopped glass and cotton cloth scattered on the wet gelcoat. After drying just shake it off and then glass cloth on it.
#464
Cleared the mold from 'snow' and this is what stays behind, a surface ready for glass.
Two molds, one has a piece of the F100 (blue part) and the other the Turkey feathers.
#465
New mold , very happy with the outcome. Some alu parts sticked in the mold but were easy to remove, I expected that this would happen.
They need a good cleanup but here they are .
Very tight seam here.
#466
Hello my friend:
Very good job, congrats, now you need clean the molds and make the first exhaust !!!
Which color do you apply over the mold for get the pieces ? Silver, grey, white... ?
My first I made in metallic grey but the paint not was opaque enought, the white is perfect, but the silver is ideal.
What you do think ?
Regards from Spain.
Carlos.
_______________________________
What you do think ?
Regards from Spain.
Carlos.
#467
Hi Carlos, thanks man for the compliment. Are you making progress to?
For the pieces I want to use white 2k primer but need to test this If it affects the sealer in the mold. I have 2ltr heat resistant alupaint and perhaps I spray the first nozzle with it just for testing with the color.
Greetings,
Peter
Greetings,
Peter
#468
My Feedback: (23)
looking fantastic peter! I have found metallics (especially silver) need a back coating of another color to give a uniform color depth. I have since given up on the silvers and just prime in the mold, as the seams typically need a little clean-up anyways
#469
Thanks Thomas, I assume it is a 2k epoxy primer that u use? Have to wait for some frekote and then.......... I make a test nozzle.
#472
Hey Peter:
Do you see this F-16B ??? Someone make it first than you, but yours is the very best, sure.
http://m.youtube.com/#/watch?v=IJyUS...ure%3Dyoutu.be
BR.
BR.
#473
I know this one Carlos, Gerald has converted his new scalejets F16 to a B version. That works quicker than my project [&:].
I am getting competition with this B version so have to set a higher standard on my future kit.
#474
My Feedback: (23)
ORIGINAL: Peter Coers
Ah, oke good luck finding a good deal. Any new forms ???
Nope, nothing yet. I have been out of town for work for the past two weeks. I hope to be home this weekend, but i leave for a flyin on wednesday. I dont expect to get much else done until august. Hopefully by then i will have the materials for the fuselage.
