New Hitec Aurora 9-Channel 2.4Ghz Radio System
#4551
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: wkevinm
Today I was finishing a new model and started to get the servos programmed and the receiver set up. I copied an existing model of similar airplane to a new model in memory position 10. I was allowed to create position 10, renamed it new a unique name and then when I tried to select it... nothing. I selected some other models, no problem, went back to position 10, but it will not select, nor will it allow me to delete it. I then copied and built models in positions 11 and 12 but agian I cannot select them, but I can delete these models.
so what I have now is
Model memory positions 1 through 9 are OK, I can select, have the option to delete.
Model memory position 10 I cannot select and I cannot delete
Model memory position 11 and 12 cannot be selected but can be deleted.
Has anyone faced this before, any ideas? wkevinm
the procdeure for deleting etc is missing a step which the mind is convinced was taken correctly.
A good sleep or walk around the block and suddenly all is often well with the world.
Following might assist:
. Aurora 9 - Model Number Reset or Delete..
. Aurora 9 - Programming Problem? - Parameters must be set in correct ordere.g. V_tail, see chart.
In need, email direct:
Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
[email protected] any time you have a question"
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
#4552
AB, CANADA
In trying to determine the issue I updated my transmitter from version 1.08 to 1.09, I also changed the transmitter so I had to select " yes "
So I deleted a model that I was not using from position 5 thus moving the one I could not select to position 9.
I tried to select, still nothing, then I found that the select screen was my problem here is what happens
the transmitter is set on model number 1, I want to select model 9
Step 1. move the cursor to model 9
Step 2. hit select
the screen moves and shows the screen with models 2 through 5
Step 3. hit select again
Then screen goes to the Model select confirm screen requesting my input.... done
the difference is I have to hit the select button 2X not only once
second test
the transmitter is on model 9, I want to move to model 2
I move to the model selction screen, model 9 is highlighted
Step 1. I move the cursor to model 2
Step 2. I hit he select button
Another test
Transmitter is now on model 2, I want to select model 9
I move to the model selction screen, model 2 is highlighted
Step 1. I move the cursor to model 9
Step 2. hit select
again I had to select the "select" button 2x
Another test
I created a model 10
Transmitter is now on model 9, I want to move to model 10
Step 1. I move the cursor to model 10
Step 2. hit select
the screen moves and shows the screen with models 3 through 6
Another test
Transmitter is now on model 1 and I want to move to model 10
I move to the model selction screen, model 10 is highlighted
Step 2. hit select
the screen moves and shows the screen with models 1 through 4
no change
Step 4. hit select again
This time it required selection of the "select" button 3 times
I repeated this test several times with varying results that being the select button needed to be presses 2 or 3 times to get the correct response always after the 1st pressing the screen changes.
I have sound on when a selection is made, so I know contact is being made... this is not a hardware issue, rather a software glitch.
another test
the transmitter is on model 1, I want to move to model 2
I move to the model selction screen, model 1 is highlighted
again
the transmitter is on model 2, I want to move to model 3
Step 1. I move the cursor to model 3
screen blinks, model 3 is still highlighted, screen still with models 1 through 4
Step 3 , I hit the select button again
I can live with this, however it appears to be a programming inconsistency.
Step 2. hit select
second test
Another test
Step 2. hit select
Another test
Step 2. hit select
Another test
Step 2. hit select
no change
another test
again
#4553
AB, CANADA
I have a question about dual rates and programming digital servos. I am using these servos on a racing airplane and once at speed they require very little aileron or elevator movement, so little that even on the shortest moment on the servo and longest practicle movement on the control surface reduced rates are required down to 40% on a non programmed servo for up or 10% for down elevator to achieve suitable control.
I have recently purchased a HP 21 servo programmer with some high voltage servos - 7245MH and 5087MH.
I can achieve limited servo travel by either programming end points via the HP-21 or by programming the dual rates in the transmitter. Is there a difference in resolution? I want as much resolution as I can get while working within the practicle mechanical limits.
wkevinm
wkevinm
#4554
Aurora 9X
Only photos currently available, still await full details.
Alan T.
Alan T.
#4556
AB, CANADA
Looks like the same radio with a bit more chrome, was hoping for something not as busy as the A9 Tx. I did see some specs that are better though... resolution is better, latency is improved.
When will these be available, presumably works along side A9 and current RX?
#4557
Banned
ORIGINAL: A.T.
Aurora 9X
Alan T.
Aurora 9X
Alan T.
There would be no purpose to post if unreadable.
Anyone can read those lines ?
Zor
#4559
ORIGINAL: Zor
I wonder if some of you guys can read the text in two of these three pictures.
Anyone can read those lines ? Zor
ORIGINAL: A.T.
Aurora 9X
Alan T.
Aurora 9X
Alan T.
Reader can then use the screen +&- feature to increase several fold.
Another has suggested that "SLT" could be linked to:
Tactic AnyLink SLT technology
Tactic AnyLink Aircraft
Alan T.
#4560
Hi,
I'm able to read the specs in the last post when the picture is enlarged.
It does not say if it is compatible with the A9 receivers, but I'm guessing it is. Is it?
Also does it have removable frequency modules so we can plug in the original A9 synthesided 72 module?
Are the updates downloadable?
Can you easily switch Modes (1,2,3,4) ?
It may be too early yet for all the information, but I'll search the web to see what I can find.
Thanks for posting the information on the 9X.
Fly4Fun,
Wayne
Fly4Fun,
Wayne
#4562
Banned
ORIGINAL: A.T.
An easier to read extract attached hereto, right click and select to open in a new window.
Alan T.
Alan T.
The previous image was getting all out of focus upon enlargement.
Only people interested in this system would bother trying to read the specs.
Zor
#4563
I am definately interested in this new unit and I am a happy user with my two A9's and a receiver count now of around 55.
It appears that they have not improved the screen to match even the easy to read color one used on the cheaper Eclipse Pro. That I could live with as I already have however what Hitec needs desperately is a cordless buddy system to at least match Futabas fantastic cordless buddy cord system.
Now what may seem like a minor feature/accessory to the majority of users is indeed a substancial improvement in the conduct of flight training. The A9,s have some wonderful features in there current system but are really Screwing the Pooch by not providing a cordless system to at least match Futaba's.
And I would ask any corporate types who may actually read this stuff to remember while a cordless system may not generate hugh sales of the cordless system itself but for us on the frontline of training out there we do tend to generate hugh sales of product and what is used on every field to considerable extent.
Hitec if your marketing research does not indicate your desparate need for a cordless buddy system then your research is flawed.
John
John
#4565
I have been waiting on a radio to come along to take the place of my trust Futaba 9C. With the Hitec 2.4 module and 9 channel receivers, this system has worked well for me. But I would be interested in the easier and more comprehensive programming options. Increased resolution sounds good but I don't know how that latency matches up with my setup. Probably somewhat better. Not being an early adopter type person, I will wait and see what the verdict is once they reach the field.
#4566
AB, CANADA
I was planning to buy a spare A9 TX and I will buy this radio if it is compatible with my Hitec receivers... about a dozen, 6,7 and 9's. If the system is not compatible I will shop for the best value and most reliable system. Which may bring me back to the A9x.
When will this system be available in North America?
#4567
ORIGINAL: wkevinm
especially given an older post:.
. Sorry, no official announcements at this time.
However, any new radios released in the future will be backwards compatible.
- Mike 03 April 2012.
Alan T.
#4569
omg. This thread has 179 pages. Ok, so without reading all 179 pages, would any of you recommend the Hitec Aurora over the other brands?
Thanks.
Thanks.
#4571
Yes I would and I use two Aurora 9's and have somewhere around fifty five plug and play aircraft all with hitec 7 and 9 channel receivers.
Recently completed a long over water flight of 48 miles on the colorado river and the fuel remaining and ground speed telemetry was most usefull.
I teach a lot of primary and use mostly my own airplane with the A9's but in cases where some may have different systems I will offer a loaner Hitec 2.4 Rx to use in his airplane untill after solo. This allows full access to the wonderful Hitec buddy cord features. Of course the only area they are screwing the pooch is the lack of a cordless buddy system.
John
John
#4574
ORIGINAL: oliveDrab
Thanks.
Thanks.
I'd highly recommend the Aurora 9. I have a number of flying buddies who are very happy with the ease of program, flexibility, and reliability of their Hitec Aurora 9 radio systems. It's a truly innovative radio platform that has forced all of the "big" radio manufacturers to play catchup with Hitec. You have to spend triple or quadruple the price of the Aurora 9 to get touchscreen programming from another manufacturer.
I fly Airtronics myself, and I really like all of my Airtronics 2.4Ghz radio gear (SD-10g, SD-6g, two RDS8000 radio systems). If I were shopping for a new radio platform, however, the Aurora 9 would be right at the top of my list.
#4575
Thanks bigedmustafa and JohnBuckner for answering my question. And OldRookie............help yourself to some yellow snow.
