Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC On Road Nitro Cars
Reload this Page >
Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Old 05-14-2013, 10:54 AM
  #2401
Jay2wip
Default RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
Lol
Old 05-14-2013, 10:59 AM
  #2402
roadrunner ss
roadrunner ss's Avatar
it do no bs
Old 05-14-2013, 12:39 PM
  #2403
ziggy12345
All finished
16.5cc Water Cooled CMB twin plug engine
2 speed
4wd
Eagle tree logging. GPS, Revs, G Force, Temp
On board camera
Gyro Steering
Note the paint job just in case you were wondering what direction its supposed to point
Old 05-14-2013, 01:28 PM
  #2404
Car-Tune
Show under the body
Old 05-14-2013, 02:10 PM
  #2405
Jay2wip
That looks extremely scary!!!!!!!!
Old 05-14-2013, 06:24 PM
  #2406
nastyboys727
ORIGINAL: Car-Tune
Show under the body
i second this ^^^^^^^^^^^^^^^^^^
Old 05-16-2013, 08:35 AM
  #2407
GT100
What kind of speeds are you looking to get out of it Ziggy? Im guessing that will be in the IC open class.
BTW, is there a difference between nitro and petrol classes in ROSSA?
Old 05-17-2013, 03:36 AM
  #2408
ziggy12345
Good point GT100. The large scale IC class is for 1/5th based kits but the line between the IC open and the large scale IC class is a bit blured. I'll need to try and define the classes better for next year
Looking for 125mph (200kph) for this car
Cheers
Old 05-17-2013, 07:26 AM
  #2409
GT100
Nice. Marc Davidson would be the one to beat with his 120mph nitro camaro. After those numbers he put up, I focused all my attention to the large scales.
Old 05-17-2013, 10:13 AM
  #2410
roadrunner ss
Do they have some thing for the jato class
Old 05-18-2013, 04:01 AM
  #2411
GT100
The Jato would be considered under the "open wheel IC" class under the ISC. I believe that there is no record for that class yet.
Old 05-18-2013, 04:07 AM
  #2412
GT100
Finally got a chance to get my baby up and running. This is its first run with new gearing and after cleaning it up a bit. Still needs some tuning.
http://www.youtube.com/watch?v=CLDX47JS4l4
Old 05-24-2013, 05:49 PM
  #2413
roadrunner ss
this my jato i just got it back tell me what you think of it
Old 05-29-2013, 12:59 PM
  #2414
Car-Tune
Cannot open or see pictures
Old 06-17-2013, 03:52 PM
  #2415
GT100
No pics but a nice video. This is a buddy of mines 4tec with a BB in it. Car was just built so he still getting used to it but from the looks of it, it's a triple digit car. Enjoy
http://youtu.be/E35iJXsSeUs
Old 07-02-2013, 08:06 PM
  #2416
ZStein
ZStein's Avatar
I notice that 99% of you guys are into "top speed" runs, and I like that too. However, drag racing the little nitro cars (4-wheel drive sedans in particular) is what really drives me. Below is a link to my NTC3, which is powered by a TRX 2.5 that I added a few degrees of timing and a few other tweaks to. I have kicked a lot of ass with this little motor but I have a pretty serious 18TZ that is quite a bit quicker. My cousin had some issue with the recorder/phone and the first run I hit a groove and got lose, but the second run is proper. Tell me what you think.http://www.youtube.com/watch?v=cHfw9nmX7ig
Old 07-03-2013, 09:16 AM
  #2417
GT100
ZStein, welcome aboard and yes, most of us like to do speed runs and some are into drag. Not sure about where the other members live but there are limited tracks for onroad racing here so the next best thing is speed. Cant beat the next guy? Go bigger . I saw the vid you posted and it runs good. Tracked pretty straight that second pass. You have any idea of your 132ft time or speed?
Old 07-03-2013, 06:16 PM
  #2418
ZStein
ZStein's Avatar
Thanks for the response, but I have no idea what it actually runs e.t. wise nor the mph. RC Drag racing use to be quite big here (Denver, CO.) but it's dry now-a-days. There are a few of us that get together and race for a few bucks, but we don't have a timing system. At sea level (I'm at a corrected elevation of over 7,000 Feet) the car will run a lot quicker/faster. I have a 91 Mustang that I grudge race up here and on the ground, and I gain about 8 tenths between here and there, so the little cars pick up quite a bit too. In fact, the last time I took one to Vagas and ran, it was the quickest thing there. Unfortunately, all that air caused the rod to fail. That little sucker was screaming though!
ORIGINAL: GT100
Old 07-24-2013, 04:43 PM
  #2419
ZStein
ZStein's Avatar
Does anyone have or know where I can buy a set of aluminum ring and pinion/dive gears for the NTC3? Anywhere in the country? The plastic gears in the rear will not stand up to my self-modified 18TZ. They are shimmed properly and works fine with my other small blocks, but strips on the first hit with my 18TZ installed.
Old 08-01-2013, 08:49 AM
  #2420
ZStein
ZStein's Avatar
Is this forum completely dead now? Sure hate that because it's very interesting. I have a question to all of the fast (80 mph and above) guys; what is a good chassis set up for those speeds? I'm asking in regards to caster, camber, toe-in/out etc. At those speeds I'm sure the set-up becomes critical.
Old 08-01-2013, 11:23 AM
  #2421
fdjizm
fdjizm's Avatar
I'm all zero'd out and my speed run setups.
toe neutral no camber, on the RS4 I am running front arms in the rear so that has maybe 1 degree of toe in or less.
Very stable at high speed and also my suspension is soft with bump stops.
Old 08-01-2013, 07:16 PM
  #2422
ZStein
ZStein's Avatar
Interesting. I didn't think they would track straight zero'd out. But it has to be a good thing due to zero drag.
ORIGINAL: fdjizm
Old 08-31-2013, 10:22 AM
  #2423
James Ray
How did you modify your adapters? What size body are you using?
Old 08-31-2013, 10:43 AM
  #2424
ZStein
ZStein's Avatar
Who is the question below directed toward?
Old 11-15-2013, 07:36 AM
  #2425
nitrohead5300
Gentlemen , for those who are looking for a 1/10 scale Ofna onroad car there is one on Ebay for sale for I think $135.00 The Ofna onroad cars are a good base for big block engines and drag racing because their diff have steel gears.
