Reload this Page >
Pilatus PC-21 - The first Fibreglass Kit on the market
Reply
Old 01-28-2004, 10:38 AM
WerHop
WerHop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pilatus PC-21 - The first Fibreglass Kit on the market
Hi Guys,
We have recieved all the information from the manufacturer of two available models of the Pilatus PC 21, The information will follow;
The first model is a 2.30 m wingspan and is 2.50 m long fuselage.
PILATUS PC21A
Wingspan : 2300
Fuselage Length : 2500
Height Off the Ground: 870
Weight : 17kg
Engine : 70 cc (3W-70i) - 7.5 shp
PILATUS PC 21B
Wingspan : 1990
Fuselage Length : 2020
Height Off the Ground: 740
Weight : 11kg
Engine : 50 cc (3W-50i) - 4.8 shp
Constuction :
Fuselage :
Prototype : The hole fuselage is built in composite with styroform and GFK as one sandwich constructional engineering. The particular segments are cuted with master models and assembled together in one half part in the longitudial axis. The two halfs fuselage are bonded the final assemble, in- and outside with GFK reinforcement. In the future the fuselage from the PC 21 B will certainly built up in full GFK technique moulded.
Wings, ailerons, flaps and elevators
Cuted from Styropore and reinforcement with GFK, subsequently with 0,8 mm woodenplates (Abachi) covered and together cemented in vakuum-pack. All power transmission Points, for the ailerons flaps hings- Retract-supports etc. are reinforcement with plywood.
Nose- and main retracts
The pneumatic retracts can be supplied, semiscale construction in ultra though aluminum. The steering nose wheel is controled with one servo swivel arm with out eny backlash.
Additional information is available on demand.
If anyone is interested please contact me for more information, a video may come soon depending on the demand from you guys.
Thanks for your time
Werner Hoppe
Hoppe Aviation Models
WerHop is offline
Old 03-25-2004, 04:34 AM
Turbo MiCHael
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Pilatus PC-21 - The first Fibreglass Kit on the market
your email seems not to work. please contact me speedster@surfeu.ch
Turbo MiCHael is offline
Old 04-09-2004, 10:37 PM
sailr
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your photos are not working. What does the pilatus pc21 look like? Do you have a web site?
sailr is offline
Old 04-11-2004, 02:47 PM
WerHop
WerHop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will fix the error and let you know when it works again.
thanks
WerHop is offline
Old 04-13-2004, 06:07 AM
GRANT ED
GRANT ED's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried to post a pic but for some reason it would not work.
Google for Pilatus 21 and you will see.
Pretty funky looking plane if u ask me.
GRANT ED is offline
Old 04-17-2004, 02:08 PM
scratchpc7
scratchpc7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know about pretty funky. I like the plane and the pictures do not do it justice. Plus for any propeller driven aircraft to have the flight envelope that this one has, it is quite amazing. What is pretty funky is the sound in flight with that five-blade carbon fiber prop.
There are pictures on www.pilatus-aircraft.com
scratchpc7 is offline
Old 04-17-2004, 04:24 PM
parabellum
parabellum's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm pretty certain people wants to see the photo of the RC model that werhop was trying to post.
Pilatus PC21 seems to be modified improved version of Pilatus PC9 aka Texan II.
parabellum is offline
Old 04-18-2004, 02:31 PM
scratchpc7
scratchpc7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Modified in several ways. The wing is not the same poly-hedral wing that is on the PC7-PC9 models, I is just straight dihedral. The wingspan is smaller. The wing is swept back about 12┬░ and ever-so-slightly the trailing edge is swept forward. The wing tips are swept up. The fuse is quite similar, and the canopy is the same. The biggest difference is the 1600 HP PT6 turbine and five bladed prop. This thing really moves out. From what I have been told, this plane flies more like a jet than a prop. With the smaller wings, and higher wing loading, the pitch performance was compared to an F-18.
If there was a smaller version available, I would probably get one; I don't want to get that big of a plane. I will probably build me one from scratch someday.
Old 04-18-2004, 09:20 PM
Mel Francis
Mel Francis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a shot of the full-size aircraft.
This would define the term- 'pretty swoopy'.....
Mel Francis is offline
Old 04-21-2004, 10:19 PM
CRAZYRYAN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok the pics dont work
CRAZYRYAN is offline
Old 05-11-2006, 08:46 AM
ScaleAero
ScaleAero's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a much larger airframe than the PC-9. Its only 30 or 32 inches wide in the cockpit... 700k/ph dive speeds....
ScaleAero is offline
Old 02-24-2008, 06:20 PM
Swiso
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just found this model by Aerobel (www.aerobel.ch) : http://www.aerobel.ch/Aerobel-Beschr...Modells.cfm#:;
Not a BIG model but very beautiful anyway !!!
Regards
AA
Swiso is offline
Contact Us Archive Advertising Cookie Policy
