Scale wing struts
RE: Scale wing struts
K&S has streamlined tubing (or at least they used to)
You can try contacting them:
http://www.ksmetals.com/Contact/cont...?Title=Contact
I have considered the same question on a similar build project (not nearly there yet). I think this source might provide stronger streamlined tubing for use as struts.
www.seacommander.com
Have fun!
Bedford
Have fun!
Bedford
My Feedback: (64)
Thanks for the help guys!
Seacommander is not taking any orders till July. Bummer
Iam kinda curious on if the K&S tubing is strong enough.I will call them on monday to see if they are.
My Feedback: (16)
CA
ORIGINAL: henson
My Feedback: (64)
Thanks for the info on the K&S tubing I kinda had a feeling they were not strong enough.They will be functional struts.Proctor has some real nice hardware.Maybe I will just replace my broken ones with some spruce.
Thanks again you guys for all the help?
GA
There is an EXCELLENT source out of Canada. They make thicker wall aluminum tubing that is airfoil shaped. I will try to find them and post it. They are a bit expensive, but well worth it. They even have special fittings for the ends for easy hookup.
My Feedback: (64)
Thanks for all the replies,
pahtreek, that would be great if you could find out there name.
vertical grimmace,thanks for the link I will call him tomorrow.
OR
I have used the K&S tubing for functional struts with no problem; just run a tight fitting wooden dowel up the middle. Shave some flats on the dowel with a plane until it fits nice, then slide it in. As strong as anything.
Jim
Jim
Wallther,
Did you get those Hobby Lobby struts in the store or order them from someone?
I am in the same situation. I need functional struts for 6 quarter scale models.
Ron
Ron
