View Poll Results: A poll
Voters: 35. You may not vote on this poll
Hooben T-55 Purchase/Build/Help
RE: Hooben T-55 Purchase Help
hi
The question is what kind of kit your are able to get, if it is a early kit i would prefer that RTR tank because your are sure that this tank do have all parts and everything fits well (because its mounted). Ich you are able to get some of the last produced t-55 i would prefer the kit, Hooben did improfe its kit very well so you shouldn t have much problems with the parts inside.
sadly i only have 1 new kit in stock :-(.
and some RTRs older versins
cu christian
cu christian
Never a fan of RTR in any hobby. Once you check all the nuts, bolts, screws, etc, for tightness and thread lock you've put the kit together anyways.
I got one of the original batch kits still setting in its box waiting to be built I know it has some over kill in flash I know the electronic mech's that come with the kit sucks but I now know what ill have to do to make it correct as I build it .
This is all part of the game of building it .Its not a Tamiya and I know it so im not going to be upset if I have to do extra work on it .
I also still have the Elefant to build to .
Jimmy
Jimmy
I can't find bearings as of yet. Since they are an internal single bushing to replace you need 9X5X4 non-flanged bearings. I contacted boca and they have 10x5x4 but you'd have to mill out the wheels which may remove too much surface material to then glue them together.
I've added bearings to my t-55. The bearing on the output shaft of a Tamiya tu would fit perfectly but you have to make some slight alteration due to the flange. If you could get this size without flanges then you'd be sorted!
That's what I meant by "can't find any of yet" Have some emails out to bearing makers/supplier's to see if anyone has any laying around. Contacted the supplier ETO used when he stocked
the wheel bearing kits, but haven't heard back.
Got an email back from a bearing supplier than can possibly make these bearings with a rubber seal. Waiting to hear back on price per bearing, will let you know when I do.
go to Boca Bearing, I am sure they can find your sealed bearing size.
Anyway I say Kit for one reason, You build it you know the tank inside and out. There are lots of things that a T-55 may need or issues that others have faced. Search a few threads and you will see what I mean. You do the work yourself your prepared for the problem areas and can work through them.
the RTR is not gauranteed to have any fixes applied, it is only stated that it is assembled.
ORIGINAL: FreakyDude
You can't. Servo works with a digital signal ( that's why there is 3 wires) and Tamiya just is variable voltage for the electric motor. What you can do is to modify the servo for using just the motor and gears but I think you are looking for a digital proportional working. You need Clark TK22 or other PCB that be able to manage digital signals.
First off, never say "can't" in a r/c hobby. Yes you can use servo's with the tamiya DMD. just use a Y harness off of the channel you using for elevation. One lead to the RX and one to the servo.
Recoil will be another story.
Found an article on the H.E.A.T site for [link=https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC8QFjAA&url=http%3A%2F%2Fheatarmor.com%2Fjoomla%2Findex.ph p%3Foption%3Dcom_content%26task%3Dview%26id%3D92%2 6Itemid%3D29&ei=Wmr6UcKAD4_68QTwpIC4DA&usg=AFQjCNH7Wqpyjjv3T6lFr9ArX1HuklIo_A&sig2=Yjhq0WciGyiGuDzA73retw&bvm=bv.50165853,d.eWU]Tamiya electronics with servo elevation[/link]. Now the question is how would I connect the servo (3 wire) to the Tamiya (3 wire) CN6 wire. Which wire matches to what?
Yes you are right. However I was talking about the stuff as is as a general concept.
I have checked the Y and didn't work fine with some old receivers. But your answer is vaild and usefull.
RE: Hooben T-55 Purchase/Build/Help
If you don't know which one to unplug, just unplug one at a time and test to see if the function works or not. It is probably ch. 2 or 3 though.
Herman
Herman
I just unsolder the motor from the servo pcb board then you only need 2 wires to the motor contacts plus you will have to cut the little stop on the first gear so it can do 360 rotation or just leave it and it will do 180 rotation only directions with pics are here at this web site .
http://www.tedpavlic.com/post_servo.php
After you do this servo mod you can hook up the Tamiya elevation wires to the tamiya elevation connector you just need to find a cable connector to match or change them to a small deans plug .
Jimmy
Jimmy
On CN6, the center post is the signal post. The other two are + and -. What are you trying to connect to CN6? The elevation servo connects with the Y and slow down to the Rx. You do not need to connect it to CN6 that I am aware of for elevation to work.
Herman
Herman
CN6 is the recoil connector point on a Tamiya MF unit the only way you can do a servo recoil with a Tamiya MF unit is .
1. look at the Heat Group site and see if they have the directions for using a servo for recoil .
2. you can buy a servo recoil control board from www.rctankhobby.com you wont need to change anything on the servo it comes with direction on how to wire it in witch is only 3 wires 1 for battery ( + ) 1 for battery ( - ) and 1 for trigger signal witch would be one of the 3 pins coming from CN6 connector .
3. something like the Clark TK-22 control board or the SLU unit .
Here is a pic of the recoil board from RC Tank Hobby .
Most guy's using the Tamiya electronics in a Hooben build just replace with Tamiya recoil unit if you got one of the later models of Hooben Tank kits they come with mounts setup for servo's they are made to work with what control units Hooben are using now witch I think is the Clark Boards now. It was control board like the SLU but there was to many problems with that setup at the time it was mostly with Hooben made gear systems for the recoil and elevation .
Jimmy
Jimmy
