Yellow Zero Flap Retrofit
My Feedback: (427)
I will be installing flaps on a Yellow Zero that was already built and the flaps were omitted. Don't know why, but these will help in landing this already heavy fighter. I have outlined the flap area using Yellows guideline. I plan on using the flap skin that I removed thus eliminating any repainting.
My Feedback: (427)
RE: Yellow Zero Flap Retrofit
OK, already have a change in plans. After cutting out the perimeter of the flap outline. There was no way of removing the skin from the foam in one piece. I forgot how tightly the skin was glued to the foam. Had to remove everything by gouging out the foam and sheeting. Will be building new flaps with ply and ribs. I do have the flap pockets cleaned out.
My Feedback: (427)
Hi Carl,
I have to do the built up flaps since I don't have any airfoil balsa sheet. I think they will look better. I made the leading edge sheet for the flaps. I glued on the hinge blocks and made pockets in the wing to fit everything in. Side formers are glued in also. Ready to make the flaps.
My Feedback: (427)
Finishing up this project. Servos are mounted and linkages are made. Made a plywood horn and the clevis hole has a piece of nyrod glued in for a bearing surface. Flaps are dry hinged for fit. Glassing and finishing next,
