RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Warbirds and Warplanes (http://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   Glow Fuel Proofing Latex Paint (http://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/8466613-glow-fuel-proofing-latex-paint.html)
TLH101 02-11-2009 08:15 PM
What is the best way to get a semi gloss, or matte, finish that is glow fuel proof over latex paint? Considering using latex on my B-17.
Warbird Man 02-11-2009 09:55 PM
RE: Glow Fuel Proofing Latex Paint
I have used polyurethane both water and oil based over latex with good results. Just make sure the latex is fully cured before applying poly (3-4 weeks) otherwise the latex will never completely dry/cure.
hellcat56 02-11-2009 10:00 PM
LUSTERCOTE available at the local hobby shop
flat or gloss
spray can
no clean up
cheap
I used it for years
TLH101 02-11-2009 11:01 PM
I have read on these forums, that Polyurethane will yellow over time, due to sunlight. Does it?
TLH101 02-11-2009 11:02 PM
Not sure I want to paint a 10ft w/s model, with spray cans.[:o]
hellcat56 02-11-2009 11:40 PM
yes it will yellow over time
As for painting a 10 ft span with spray can
I dont go for a heavy coat when i fuel proof usually a very light coat
all I want to do is fuel proof it
but
its really up to you and what your comfortable with
Are you going to the Bomber field warbird in June?
if so
lets look each other up.
Hellcat
bigtim 02-11-2009 11:50 PM
ORIGINAL: TLH101
as a painting contractor in Ca. here's what I do know, I am sure there is alot more info out there as well.
oil based polyurethane does yellow in the sun over time, the exterior less than the interior version, since the ext. contains UV blockers in its formula for durability outside, what actually yellows is the resins in the material, its available in brushable form, or spray cans.
water based urathanes do not yellow in the sun but,
most water based urethanes will soften with exposure to fuel and residue after a few hours of sitting if not cleaned up, the exeption is WB Poly thats intended to be used for bar tops since its formulated to be alcohol resistant, Varathane makes a product called Diamond finish that is alcohol resistant and after exposing it to fuel it seems to work well after its been let to cure, at least 2 weeks, I haven't let it sit over night but after a couple of hours it seems to hold up well as a clear coat, before I let fuel sit on it the plane sat for several months.
the Varathane Diamond finish is the material that I have been using for glassing my projects,I clear coated my spitfire with it and its held up so far, it also available in brushable, and spray cans as well.
both the oil based, and water based poly in the brushable version, can be sprayed out of a HVLP gun, or airbrush of course.
another alternative paint product, which I have pretty much switched to for painting my models is warbirdcolors paints http://www.warbirdcolors.com/usa_home.asp so far I have been happy with the results, with a small learning curve in spraying the material.
I am sure you have read some postings on the product, but briefly its a catalized water based polyurathane paint, adding the catalyst/crosslinker causes the paint to become fuel resistant to 15% nitro, has several authentic color palettes, allied,axis,etc.... http://www.warbirdcolors.com/usa_home.asp
it has a quite high spread rate, doesn't need alot of paint to cover the area, I use a large syringe to messure only the amount of paint I need to spray a particular area at one time, and only catalize the material I will use in that small amount of time, about a 1/2 hour, the material is not the cheapest but it goes a long way if used sparingly, the colors cover quite well after just a few coats,the clear builds up nicely as well when I order it I try to build up a large list of material so it cuts down on shipping one can at a time can be a bit expensive,I am building up a fairly large collection of colors, next will be the colors for my FW190A8 I am building now.
Warbird Man 02-12-2009 09:12 PM
Lacquer and epoxy based clears can also "yellow" over time. There are some "clear" water base polys out there available in quarts that can be sprayed. (not that I'm trying to sell you on poly, just suggesting it) But it's some tough stuff, although it's hard to find anything flater than a satin finish.
Nelson Hobby supplies a Flat clear water base poly with available cross linker to make it fuel proof up to 50% nitro. I haven't tried it yet, but I hear it's very good stuff but abit pricey. www.nelsonhobby.com
CGAV8R 02-12-2009 10:30 PM
I use the Nelson, good stuff!
Aaron D.
phatbob02 02-13-2009 03:29 AM
Minwax Polycrylic Protective Finish is a crystal clear, fast-drying protective topcoat for use over bare wood, oil- and water-based stains, paint and wallpaper. It has very little odor, is non-flammable, cleans up easily with soap and water, and can be recoated in only 2 hours. Minwax Polycrylic resists damage from abrasion, scuffing, chipping, water, alcohol and other common household chemicals.
