Hostetler Lancair ES Build with retracts.
I started this build in 2010. I am a slow builder so I have been taking pictures along the way.
The Lancair ES does not call for retracts but I think that a plane looks cool with them.
Being unable to find retracts for the IV version I decided to use the Lancair ES wing because it is thicker and the retracts that I have will fit.
I am planning on using Dave Platts' Spitfire Retracts.....not scale looking on the ground but when they are pulled up, nobody can tell the difference..
At the moment I have no idea of what retract I will use for the nose....Maybe someone can make a suggestion as I near that point in the construction.
I'm getting ready to go to the Gateway R/C Club Meeting now...Will start posting tomorrow.
RE: Hostetler Lancair ES Build with retracts.
The fuselage starts out as a basic box. Pre-cut pieces are added to give the basic shape.
You might have noticed that I built an extended engine mount for my Saito 300 Twin..
A little more detail is shown 2 steps further down in the thread.
I fitted the engine to the mount and mounted it....then I removed it from the mount.
I attached the newly built mount to the firewall with 30 minute epoxy.
This activity was performed before the planking was started.
To keep these formers in shape and to help me from breaking them as I applied the balsa sheeting, I used (3) 1/4 square stringers on each side of the fuselage.
The kit was cut by Precision Models.
Three inch sheeting was supplied to mold around the model. I found this difficult to do so I cut the sheets intoinch and a half wide planks and then proceeded to plank the model.
The white stuff you will see in the planking and elsewhere in pictures is spackling compound...it fills holes and low spots very well and sands like a champ.
Oh yea, the area where the cockpit will be is planked at this time also....I plan to remedy that later on in the build. As for now, it adds strength and holds the shape of the model very well....I also plan on doing the cockpit (carpet and seating) as well as nav lights.
It's going to take a while.
This is a closer look at the extended engine mount for my Saito 300 Twin.
After the epoxy had set on the engine mount box I fitted the engine to the mount.
When I was satisfied with the fit I removed the engine and epoxied the mount to the firewall.
Afterthe epoxy curedI drilled holes thru the box and the firewall anddrove dowel rods thru from the front of thebox thru the firewall
andCA'd them intoplace. I felt that this would make a more secure attachment. (see the little black dots on the secondphoto.)
I did not plank the bottom of the fuselage....not even yet...
I want to be able to put push rods in their proper places to the elevator and rudder.
I also want to be able to put in servo mounts and receiver/battery mounts.
Maybe even put in a smoke system.
Also need to make allowance for nose gear box, mountand steering.
It surely has gotten cold here in Jacksonville, Florida.....24 degrees tonight and 49 high tomorrow.
Now I remember why I moved down South.
It's good building weather but on Saturday it is supposed to get into the 70's again.
Building will slow down then....will have to fly.
Plan on seeing more posts tomorrow.
Mmmmmmmmmm........elevator halve?
Let's give it a shot.
Hey! If you have any questions along the way ........... I don't wanna know.
Seriously, send them along and I'll do my best to answer them.
More elevator pictures.
Horizontal stab comes next.....as you can see...a fit is already in progress in the second picture.
Horizontal stab nearing completion.......
Hinges positioned and control horns bent for installation at a later point in the build.
Thanks, Jason.
I am more in favor of doing it with pictures...
Sometimes I get wordy but that is when I don't have much progress to show.......as in the wings.......That's next.
This is a picture of what the original landing gear looked like....no one makes it for r/c aircraft. that's why I am using the spitfire retracts.
The wing.
STARTING THE WING
AT POST # 29. THE WING INSTRUCTIONS ARE MUCH BETTER...........I LEARNED FROM BUILDING THIS WING.
PLEASE LOOK AT THESE TOO...THEY MIGHT OFFER SOME INSIGHT ALSO.
I couldn't figure out how to build it with those little tabs on the bottom, so I decided to build it upside down.
It kept the spars straight and nice and flat.
Warning.....Don't cut the spars short (as I did). Because of this dumb move I had to splice and reinforce them.
They have to be as long as the leading edge...
I was missing 4 spars so I bought them at my local hobby shop.
Be sure to leave the leading edge stick up above and belowthewing ribs so thatthe wing sheeting will meet with it properly.
STARTING THE WING
A couple more pictures of the wing build.
The ribs came neatly packaged in their own bag as did all of the other items that you would consider as loose pieces.
The cutting was excellent.
