9th RC airboat build - Selph Inflicted .40 series Tapered Flat Bottom
This boat will be named "Jacob's Ladder" for my son. When he's old enough and if he wants it, it will be his boat.
This is the beginning of a new build. I am building an SI Tapered Flatty. I need a dry ground/dedicated air rudder boat and this should fit the bill. I have a whole pile of engines ranging from wimpy PeeWee Herman to big and beefy like Hulk Hogan on steroids. So it will be a fun boat to experiment with... Maybe 55mph on land??
I couldn't find 1/16" plywood any bigger than 1'X4' so I had to make my own. I took 1/8" Maple plywood pulled off an old door from my house and sanded it down with a floor sander to halve the thickness. It worked beautifully plus it'll have the character of old growth 75+ year old wood. I'll be marking out the other pieces over the weekend and hopefully get some pieces cut out.
I'm taking the Tapered Flatty plans one step further (no pun intended?) and adding a step to the keel. This will greatly reduce the wetted surface when running on water and hopefully increase the speed potential. I'm going to cut the main runners out tomorrow and look at them to see if I want to do another stepped hull or not. I think I will, and if it totally sucks, chop it off and re-skin the bottom.
I cannot find any information on step hulls and where the hell your supposed to have the step located? My last step hull flatty was a bit of a flop as I put the step in the middle of the hull. That boat seems to suck itself down and doesn't go nearly as fast in a straight line as it does in a turn. I don't want to have another flop like that... SO where the heck do I put the step?
I decided to scrap the step hull idea for now. I'm gonna build the boat according to the plan and add a step later on if I feel so inclined.
Main runners are rough cut - still need to cut the bulkhead slots, rake, and rudders. I have the bulkheads marked out and ready to cut. I'm using Liteply for the bulkheads which I'll reinforce with balsa and fiberglass at the seams. A few more pieces to cut and I can start assembling the hull.
The distance between the uprights is 4.5". Overall hull length is 29.50" and widest part of the hull is like 17.50" or so.
Sweet! It'll be a .46 sized engine of some sort. Thunder Tiger .46, Super Tigre .45 or Jett .56LX... The latter might make it go airborne, so I'm not sure about that yet.
Making more progress on the SI Tapered Flatty. I'm going to name this one "Jacob's Ladder" for my son.
Got the bow "nose" piece made. It's made of Ash. I also have the control cables plumbed and test fitted. I'll possibly start assembling the frame and bottom skin in the next day or so.
More stuff done on the SI Flatty. Added balsa triangle stock at all junctions on the keel and bulkheads for extra support. I have the top sheeting cut and fitted as well as the radio box supports.
Thanks for looking and offering your help, Andy. Thanks for the compliments as well. This is a budget build - building it completely from stuff I already had on hand. Old plywood from a door, scrap flooring underlayment, and spare hardware. Trying to find hobby plywood wider than a foot is pretty tough and expensive, so using this stuff I have works well. The dimensions in the plans are a little funky - odd fractions of an inch - so I fudged some of them for ease of building. Overall, it's a nice design, easy to build, and it should be light and hopefully quite fast. The only pieces I have left to cut out is the side sheeting. Otherwise everything else is pretty much ready to go. If I'm lucky, it'll be RTR before the snow flies.
I finally got the side sheeting glued on. I should have made a jig to hold the sheeting in place instead of using masking tape; my sheeting moved a little bit after I taped it making a small gap between the side sheeting and the top sheeting. No big deal really, I'll just add a small piece of square wood stock of a different specie like I've done on other boats to accent it a little. As pictured, the hull is very light. Maybe 12-14oz so far.
edit: added balsa triangle stock around bulkheads and side sheeting. Added the radio box lid support also. Still a ways to go, but it's coming together nicely. As pictured with servos, hull weighs 2#11 3/4oz. I really really hope to come in less than 6# RTR minus fuel, but I'll have to wait and see. Beefing up the bulkheads and stuff for the top sheeting added some weight I'm sure. The engine and exhaust will be close to a pound, and I probably will have half a pound in the top sheeting, epoxy, and hardware. I'll have some fiberglass work to do yet too...
Not much different than the last photos... Fiberglassed outer sheeting seams and coated most of the inside of the hull with thinned finishing resin. A few more loose ends to take care of and I'll glue the top sheeting down.
Progress has been slow due to health reasons. I have gotten the top skin sheeting glued on, engine mount assembled and fitted, and I put the first coat of dyed epoxy on the bottom keel of the boat. I didn't dye the epoxy real dark for the first coat since it'll need more than a couple thin coats to be well waterproofed. I'll dye one or two more coats and do a final coat of clear. All surfaces of the boat will be just clear epoxy except for the keel. The reason I'm dying the epoxy on the keel is because I had to make 1/16" plywood from 3/16" plywood and the top ply got a little thin allowing the glue that holds the separate plies together to show through the top veneer.
I'm still planning to use a .45 SuperTigre Diesel conversion engine on this boat which will either have a 3-blade 12x6 or 13x6 2-blade prop.
Second coat of dyed epoxy on the keel. I went a little heavier with the pigment this round just to get it done. I'll do one coat of clear over the top after a light sanding and thorough cleaning. My process to mix the epoxy is pretty easy - mix equal parts resin and hardener and thoroughly mix. Add pigment and mix thoroughly again. Add about 10-15% methanol to thin and mix. Brushing it on thin is important as epoxy has a bad tendency to fisheye, especially with additives in it.
It looks nicer than it would have with just clear on it given that dark brown glue showing through.
I am doing okay. I get to wear a heart monitor for two weeks to rule out other issues.. As of now, the doctors say the issue I'm having is benign, but it could be a precursor to other things if the right circumstances happen at the same time. Not likely, but possible. I'm knocking on wood for now.
As as for the boat - all I really got left is getting the hull all coated up and re-installing rudders and linkages. I have some trim work to do on the outside edge, but that's the worst of it. Most of what's left is easy - I just need to find the time to do the work.
Put a first coat of thinned finishing resin on the hull sides and radio box lid (not pictured). The dyed epoxy looks pretty good against the natural clear coated sides. The keel is Baltic birch and the sides and top skin is old antique carmelized birch plywood from an old door. I thought for a long time that it was maple, but the more I look at it, the more I see the birch in it. I love the color it gets when it ages. Anyway, here's a couple of pictures. I wanted to get two coats on the bottom before I trim the top and coat the top and engine stand.
