Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
New Rudder Only actuator
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Old 06-16-2016, 11:11 AM
jaymen
jaymen's Avatar
Default New Rudder Only actuator
I need to post a picture, sorry, I'll get one. These actuators are motorized, and are more powerful than an Adams.
They are about the size of an Ace Standard. I'm in the process of making up a small board to allow these to be used with a digital proportional radio, like my GG version.
They will also work with a conventional pulse radio with the addition of a small driver board on the actuator, which I custom build for them. Although they will work with the Ace Pulse Commander receiver, the receiver itself needs a small modification to work with the actuator driver.
Right now, we are testing these for reliability and performance, but so far, all the feedback has been very good. I'm taking orders now in advance to get a large group order to get the price down, so let me know if you are interested, no deposit required. I'm probably only going to do a one time run of these, as the demand is fairly limited, so the larger the order, the lower the price will be. The same applies to my GG reproduction actuator, as I'm going to make one more run of those as well to get you guys the best price I can.
Old 06-23-2016, 12:48 AM
tdkallner
If it isn't on YouTube it doesn't exist. Here are som links to video about the RO-Tobe as set up and in action
https://www.youtube.com/watch?v=IsmvchocQY4
https://www.youtube.com/watch?v=1xVA-2AVcr4
https://www.youtube.com/watch?v=0sWcx6ULa3M
ID:	2169223   Click image for larger version
ID:	2169224   Click image for larger version
Old 07-01-2016, 09:08 AM
jaymen
jaymen's Avatar
As an update to the original post:
The actuator is made by Tobe, and the electronics package I'm making for it will include a special rudder only recoder by Phil G. I have integrated the recoder with a driver that allow the use of several different voltages and one single voltage supply, or separate voltage supplies. The reason for this so you can use it with not only Tobe's actuator, but also original Adams and magnetic actuators.
Old 07-26-2016, 07:04 AM
E-Challenged
Will the Tobe actuator work with any modern 2.4 GHZ transmitter on aileron channel with add-on board? Will add-on install be simple and not void warranty of transmitter? I'd be tempted to buy a modern 2.4Ghz single channel rudder-flapper equivalent to my ancient Ace Pulse Commander
system from the '60's. Wish somebody made Adams baby/baby twin actuators. Remember the wimpy Bentert actuators, how about "Grid Leaks" newsletter, Dick's Dream, single tube 3S4 receiver with Gem relay, Ahh yup!!
Old 07-26-2016, 07:30 AM
jaymen
jaymen's Avatar
Yes, it's a plug in device, just like any servo, so no modifications are done to your transmitter or receiver, so it will not void your warranty. Works with the new 2.4 GHz radio systems, and older AM,FM, & PCM digital proportional radios as well.
If you want to PM me I can give you more details.
Old 07-26-2016, 07:44 AM
jaymen
jaymen's Avatar
Default Re-Coder PIC PC boards available
For those of you who have purchased Phil G re-coder PICs for Pulse Proportional emulation, Crist has made and sent me some circuit boards which greatly simplify the task of wiring up the re-coder PIC to a H-Bridge driver board and servo plugs. This universal board will work for rudder only and galloping ghost, and allow you to use a variety of options as far as battery voltages for the actuator. The re-coder circuit with driver can be used with any original magnetic actuator (Adams style) or motorized actuator (Rand/Controlaire/Tobe) using the PC board as it has several options.
We designed the board so if you have Phil G galloping ghost PIC, it can be used with a rudder only actuator by adding the elevator servo plug.
Keep 'em flapping.
Jay
Old 07-26-2016, 08:06 AM
tdkallner
Hi there, the actuator both the GG-TOBE and the Adams Clones are connected to any receiver like any moder servo just calling for a PhilG recoder in the between so no modification required on your radio. Follow it at
http://singlechannellersreunited.co....forum.php?f=28
The GG-TOBE and the Tobe Adams Clone shown here together with the Re-coder that plugs in in any modern receiver. That's it!
Cheers
Name:	GG-Tobe & Adams Clone + Re-coder.jpg
Old 07-26-2016, 09:24 AM
otrcman
Hi Jay,
I just now tried to return your phone call from this morning. The number that I have for you doesn't seem to work. Could you please call again ?
Thanks, Dick Fischer
eight-oh-five 489- four oh 78
Old 07-26-2016, 02:01 PM
jaymen
jaymen's Avatar
949 699 0439 is my number, call after 6PM PST, I'm in California.
Old 07-26-2016, 06:21 PM
049flyer
My Feedback: (18)
049flyer's Avatar
Hi Jay:
Any idea what the estimated price will be for these actuators? I may want several of the RO Adams type.
Gene
Tyler, TX
Old 08-08-2016, 11:40 AM
H5487
H5487's Avatar
Hi Jay,
Do your Galloping Ghost actuators have a recommended max weight or wingspan for the models they can control?
Harvey
Old 08-09-2016, 08:34 AM
tdkallner
The GG-Tobe is intended to be an almost direct replacement for the old Rand and as such I would expect it to fit the same range of models, what flew with the Rand will fly as good with the GG-Tobe. One of my test benches weighs in at almost 2 lb. with a 50" wingspan.
Tobe
Old 08-10-2016, 03:00 PM
jaymen
jaymen's Avatar
These actuators typically were used in planes with engines under .29 cu. in. and for that size engine they should be fairly sloy flyers. The ideal engine size works out to be somewhere between .074 and .21. You saw many plane designed for Ghost in the .15 to .19 cu. in. range. An Andrews H-Ray, GiGi, Mambo, Rodent. Whiz-Kid, CG Skylane, Lil Tri-squire, Esquire, Headmaster are all good galloping ghost ships.
Old 08-10-2016, 03:31 PM
H5487
H5487's Avatar
All familiar names from my early R/C days!
...ghost ships.
I think you just named the plane that I'm gonna build for your actuator!
Harvey
Old 08-19-2016, 06:57 AM
H5487
H5487's Avatar
Jay,
Any news on the batch of actuators that you're building?
Harvey
