2 inch (50mm) dia rubber (not plastic) insert for an rc starter.
I have the TOC Terminator starter. It is geared.
It is very strong; It can start a 120cc inline twin gas engine.
But;
Mine was delivered with a very hard plastic cone; It slips on the spinner.
I tried a friends TOC Termiator; His was delivered with a rubber insert, and worked fine.
So;
I'm looking for a rubber insert with a 2 inch (50mm) outer dia.
Anyone knows where I can buy one? A link, please?
On most advertisements out there, the diameter isn't indicated. They don't want to sell any, it seems.
But;
So;
Have you gone back to the seller/distributer/manufacturer? Maybe the hard plastic was an error. In any event, you know from your friend's starter that the soft one is available, I have not measured my starter cones, but it seems that 2 inches dia is about right, maybe a standard?
My Magnum starter (which is also quite strong) inserts are approximately 1 1/4" in diameter so you can rule these out in your quest:
http://globalservices.globalhobby.com/part/237960.asp
I imagine most standard inserts are that size. Good luck in your search.
http://www.terapeak.com/worth/toc-ro.../262382191962/
http://www.ebay.com/itm/TOC-Roto-Ter...MAAOSwgyxWV8XW
Mine are standard also, likely the 1-1/4 inch cited above. Thanks for correcting my assumption. BTW the geared starter looks like the motor is a car starter. Anyone made their own from one of those?
W8ye,
I ordered a couple of those today.
What I'm afraid of, is that I receive stiff, hard plastic inserts, even though they say its rubber......
So, I was hoping for a link to someone selling 2 inch rubber inserts. Often, you can see on the picture that its actually rubber, you know......
On the TOC picture, they are shiny, like plastic....but you never know...
The starter itself is incredibly strong, and the gear is metal. No Belt involved.
It is actually rubber, not plastic!!!
Very happy now.
The starter turns a ZDZ 90, or a Valach 120cc inline twin fourstroke with ease.
