View Poll Results: What is Your Favorite Brand Of Alkaline AA?
Walgreens
0
0%
Kirkland
0
0%
Panasonic
1
6.67%
Rayovac
0
0%
Eneloop
2
13.33%
Duracell
7
46.67%
Energizer
5
33.33%
CVS
0
0%
Sony
1
6.67%
Other
0
0%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
I will be doing a comprehensive test of many many alkaline AA batteries, but I need your help to choose which ones! Please let me know which brand AA battery is your favorite and which one you would like to see compared to see which is the best!
Please either comment here or on youtube thanks!
https://www.youtube.com/watch?v=WvoRP_Z6jYM
Hi gaaunapoi ,
I'm not looking to pick apart your poll , but the Eneloop is not an Alkaline AA cell , it's an NIMH AA cell , and are my #1 favorite NIMH rechargeable cell for my RC Transmitters .
Yes, the eneloops are rechargable nimhs, and so are most of the other rechargable AA batteries. I am not sure if you mean alkaline or nimh? Lot's of people just call any AA size battery "alkaline", wether rechargable or not.
Hubert
Hubert
Depends on what you want the alkaline cells for. If for toys and you will use them quickly Energizer is likely your most cost effective brand. If, however, you are looking at long term use and storage you can't beat Duracell.
Nah, for rechargables eneloops are the best. You need low self discharge. Duracell makes all those ads, but I find them absolutely nothing special. They are better than SOME other brands, but definately not all. They are good for things that sit for 10 years without use... I generally just buy the highest capacity batteries with a reasonable brand, because eneloops aren't readily avaliable. I find energizers to work pretty good, and have reasonable prices.
Alkalines? I avoid those. If I buy them they are duracell, because costco sells them in packs of 48
This is an important factor for my battery selection:
Eneloops = 1.2Volts
Alkaline = 1.5Volts
If I'm using a TX / RX pack, camera, wireless device, etc. ....I INSTALL ALKALINE. Typically, if the device requires 4 X AA batteries, it will perform well at 6VDC (alkaline) and may not get enough energy at 4.8VDC to provide the user with the best performance.
Eneloops = 1.2Volts
Alkaline = 1.5Volts
Well, not necessarily. Yes, alkaline is a higher voltage, but don't forget, that the 1.2 volts on a nimh is NOMINAL voltage, not max voltage. A fully charged 4 cell eneloop pack will be at around 5.8 volts. They have a fully charged voltage of 1.45 volts, but may peak even higher. Most alkaline that I have had are around 1.6 volts, so yes, you will get slightly better performance on alkalines, but not much. Definatley not noticible in a transmitter, and the majority of people that are running aa packs in transmitters use eneloops. Alkalines are the last thing I would use in a rx pack.
Let's not forget that a whole bunch of TX's are designed to run 8 cell NIMH like my trusty ol DX-7 for example . Jacking up the input voltage does nothing but make the linear regulator have to work all that much harder , dumping the excess voltage as heat .
Also , just to throw a real stinkbomb into the thread ; Sure , I use Eneloops and only Eneloops in my TXs , but the airplanes themselves ? LIPO or LIFE all the way ! LIPO for electrics (naturally) and LIFE for the RX packs on glow or gas powered . I do not and will not trust any airplane I own to an AA RX pack , no matter what ........
Eneloops = 1.2Volts
Alkaline = 1.5Volts
Eneloops = 1.2Volts
Alkaline = 1.5Volts
I do not use alkaline or Eneloops in any of my aircraft or transmitters. I use LiPo and LiFe.
I agree, I use LIFE for rx packs. Eneloops in my TX, because they do have some advantages. First of all, a lipo is the last thing I need in my tx. Storage charge, is one. I also don't want to let a lipo sit connected to anything. Life is fine, but the discharge curve is a bit flat, and it's hard to keep track of in a TX. Sure, eneloops weigh a bit more, but I don't care, , it's usually less than 1000 grams any ways. Now back on topic...
I personally don't find a difference between a fully charged eneloop and a new alkaline. One thing I noticed, is that most AA chargers don't charge fully, both of mine only do up to 1.2-1.3, no idea why, might just be my chargers. For this reason, I tend to us my rc charger to charge everything That way, I can keep track of mah, and get them fully charged and peaked. You can even put them in a 4 or 8 cell holder to charge if you don't want to do it one by one.
Hubert
Hubert
