Trying to build an F/A-37 Talon
NC
I went to see that new movie "Stealth", and the first thing that came to my mind when I saw the "Talon" was building one. I do realize it is a fictional aircraft and may not have any chance at flight as an r/c model, but i'd like to try!
Anyway my problem is I can't find any reference material at all! All I can find are those screenshots from the movie, which aren't doing me any good. It would be nice to at least have some 3-view drawings or at best maybe Revell or somone will come out with a static model. More stuff may appear as time goes on but if anyone has any websites, ideas, or knows of any possible reference material it would be much much apreciated!!!
RE: Trying to build an F/A-37 Talon
I haven't been to the movie yet but from the trailer off the net I noticed that all the designs on there do not have a vertical tail. The inference is that they are relying on computer controlled drag brakes and/or thrust vectoring for yaw damping. For a model that isn't going to be a very practical idea. So the first thing you need to do is add a vertical fin or two. Adding them to the belly would help reduce the visual issue as long as you can get enough area.
As for 3 views I suspect you'll just have to study the screenshots and make your own. From there make up some 20 inch span test glider models of foam and balsa to test the fin area, cg placement and other factors. If it won't glide as a test model decently then you won't be able to fly it as an RC model.
NC
True it is probably computer controlled, much like the F-117. But if you look closly at the screenshots you'll see that it actually does have fins that act as stabalators. They are hard to notice since they're almost flat, but i'm wondering if it will be enough of an angle to be used as a fin. If it doesn't work I will try putting a fin underneath or something.
I think I'm going to check out Scifi-Meshes.com, that was one of my hits on Google, maybe I could get some help there.
NC
Well I built 2 foam gliders and they both fly perfectly! I couldn't believe it[X(]! One has the wings in the tucked position and one has the wings out. I finally found a 2-d view on the Stealth website, but its only the top, its in the "military briefing" videos. Now I just need the side and front views. Getting closer!
ORIGINAL: Jason233
NC
Yeah they are similar to the F-117, which might make it hard to work out the mounting but, to update my progress, I'm just going to have to wait until the DVD comes or more info gets posted to get more research material. I'm hoping they will have some behind the scenes/how they did it stuff on the DVD. I've already checked with Sony Pictures and as is to be expected, no help from them. Just a 3-view, thats all I ask!
If I had to pick a favorite part I guess the first thing that comes to mind is when they were chasing the UCAV through the mountains after the SCUD strike, those cave flyby shots are so cool they almost make me cry.
ORIGINAL: crispy6491
The Tail fins are sort of the same as the F-117 Nighthawk. I saw the movie. If you have, what was your favorite part?
Yeah it got real silent when Jamie Foxx's character crashed. Everybody in the theater got quiet. It was real sad when the UCAV got blown up at the end such an ugly ending for a beautiful plane
Hey if you want to get some good views go to movieweb.com type "Stealth" into the Search bar and then click on the Comic-Con Sizzle Piece.[sm=biggrin.gif]
Found some pictures here you go
http://www.movieweb.com/movies/hi_re...025/hi/co1.jpg
http://www.movieweb.com/movies/hi_re...025/hi/co2.jpg
http://www.movieweb.com/movies/hi_re...025/hi/cod.jpg
hope these help!!!!!!!!!!!!!!!!!!!!!!!11
stability during low speed flight take off and landing has stumped me from the very start , after 4 months of pondering the idea of using a couple of gyros is the best thing i have came up with. I welcome all ideas and comments
