Club Enya
Old 09-12-2005, 03:22 PM
simark
My Feedback: (12)
simark's Avatar
Default Club Enya
AARRRGGGH
There's nothing like iron in your pistons to stir the blood of a RC true warrior!
(Plus she doesn't look bad either - the singer, that is).
brickwoodward (05-09-2023)
Old 09-12-2005, 04:16 PM
Hobbsy
Hobbsy's Avatar
Default RE: Club Enya
Enya .45 SS, .50CXTN, .46MKII fourstroke, .53TN fourstroke, a 1.55 and a new .25 Diesel soon to be two. It's a shame they are so poorly marketed because they are buy it and run it without issues engines. And, for a long time too.
Old 09-12-2005, 04:19 PM
jlkonn
jlkonn's Avatar
I have a 20 year old R120 4-stroke that has sat for a long time and needs going thru.
Is there anyone that goes thru these engines?
Thanks!
JLK
Old 09-12-2005, 04:25 PM
simark
My Feedback: (12)
simark's Avatar
09II, 15IV, SS40BB and the impossible to adjust 60X Heli.
Old 09-12-2005, 04:57 PM
JPMacG
Really like my new 50SS. Light, powerful, great throttle response. Perfect engine for a 3D profile.
Old 09-12-2005, 05:26 PM
donkey doctor
Hello; I have two 46 four strokes that I really like, I have had a few 53's and a 120R, and a 15II. All good, as well as this little 40 with open rockers. I would like one of those 15 diesels.
Old 09-12-2005, 11:06 PM
downunder
downunder's Avatar
Enya 35 model 5224 (round intake), 35 model 5224 (square intake, ball raced), 45BB model 6001, 40 model 6002, 45 model 6002, 60X and 80X, Shepherd Moons, Memory of Trees, Watermark
Fuelman
I think I'll join this club too.
Have lots of them, all good runners, always dependable.
49X- 2 each, 35SS, 40XTV, Several 60 two strokes, 45, 46 four stroke, two or three 91 four strokes, three or four small block 120 four strokes, two 120R's, and a 155R.
Used to have the 45, a couple 15's and a 19. All good engines.
Does anybody have the 180 two stroke, or even seen one????
....and by the way, I'm looking for: an 80 four stroke complete with muffler and a pipe, and a used muffler & pipe for the 91 four stroke (OS and magnuim will fit).
Old 09-13-2005, 06:51 AM
rcdude7
My Feedback: (264)
I have two .46 fourstrokes, one .90, one 1.20, one R120 and a .60Xaac
All great running engines
No iron piston enyas in my corral though.
Old 09-13-2005, 07:18 AM
Hobbsy
Hobbsy's Avatar
Brian, I have examined the 1.80 at the Toledo, it exhibits high quality.
http://www.modelflight.com.au/rc_mod.../enya_180x.htm
Old 09-13-2005, 07:55 AM
PlaneKrazee
My Feedback: (14)
PlaneKrazee's Avatar
Two R155's, one 240VT, one 120-4c, one 90-4c and one 60XF-III GM10 S AL-Chrome rear exhaust.
I really like the 155's, they are very fuel efficient and powerful. You need to do a few things to make them reliable for aerobatics and quiet them down. The 60 has the best cylinder/piston fit of any engine I have ever seen. Without the glow plug installed the engine can be rotated smoothly and easily thru TDC, with the plug installed the engine can't be turned over without a prop.
I would like a get a .53 for a small biplane.
I don't think they are being imported to the US anymore, The .53 is the only four stroke listed on the website and the two stroke count is down also.
Old 09-13-2005, 08:08 AM
Hobbsy
Hobbsy's Avatar
Brian, here is a link to more, these folks are quick.
http://www.modelflight.com.au/powered_enya_engines.htm
Old 09-13-2005, 09:01 AM
downunder
downunder's Avatar
ORIGINAL: hobbsy
Even quicker when they're a 15 minute drive from home
Old 09-13-2005, 09:39 AM
Hobbsy
Hobbsy's Avatar
du, dieseldan and I each bought Enya .25 Ds a few months ago, I'm about to buy another. They finally added Enya to their engine links, you had to do a search to find them before.
Old 09-13-2005, 10:10 AM
PlaneKrazee
My Feedback: (14)
Wow,
Those prices are high for the four strokes!
Old 09-13-2005, 10:19 AM
LaCerne
LaCerne's Avatar
I have Enya: 11CXTV, 15TV, 19XTV, SS25BB, 40XTV, 45TV, 45CXTV, 2-GP60XLF-4(geared pump, rear exhaust), 60XF-4, 80XF Ring. Four Stroke Enyas: 35(open rockers), 40(open rockers), 53.
I would like to find a 49XTV, and a 41-four stroke.
I like my Enyas. The 45TV was my 1st throttled engine. I bought it cause it was cheaper than OS. Didn't kmow I would like them better!
Old 09-13-2005, 01:39 PM
fokker20planes
My first Enya, .09IV I bought off the bay for only 26 dollars! People say they don't have great power but I would disagree. Plus I never had a smoother transitioning engine with such a low idle. Proud to have joined the club!!!
Old 09-13-2005, 10:13 PM
PlaneKrazee
My Feedback: (14)
Has anyone else had a problem with the needle valve stop springs not having spring to them? My needle settings have been changing in flight on one of my R155s, always goes lean. I think I will try replacing them with the old part from Supertigre carbs.
The reason the setting was creaping was one ear is missing from the spring, dough!
I checked the needle valve springs from the ST carbs, the detent is at the end of the spring steel and will not contact the Enya needle valve splines.
I would prefer the ST spring, it seems to be better spring steel. I think I could make a die from a piece of 1/4" thick steel with a saw kerf on both sides and then ca a couple pieces of 1/32" piano wire to the face of my vise and mash the works to extend the detent.
Old 09-13-2005, 11:06 PM
CCRC1
My Feedback: (13)
CCRC1's Avatar
Me to! .09, (4) .19's, SS.40, SS.50 ring, SS.50CX, .80 4 stroke.
I just wish someone in the US would pick up the distributorship that would (1) stock parts and (2) import the entire line. I would really like to have one of the .049 R/C engines from Enya.
Old 09-14-2005, 09:09 AM
MyWay
Best kept secret for power to weight are the enya 30ss and 35ss.
Old 09-14-2005, 11:16 AM
Dr. Bellows
My Feedback: (7)
Dr. Bellows's Avatar
Belong to the club also:
53-four banger on Seagull Spacewalker II
SS 40 on an Uproar
SS 50 in box for GP RV-4
SS 15 on a GP Slowpoke
Sweet engines
Old 09-14-2005, 03:16 PM
Sport Flyer
My Feedback: (10)
Sport Flyer's Avatar
Can I join too?
Enya 15III, 15IV, SS30BB, 90FS, 120R FS, and 155R FS (only one that hasn't yet seen fuel).
Trying to make up my mind if a Fox 25BB or the SS30 goes into my FF Taco.
Old 09-14-2005, 08:38 PM
Fuelman
Thanks Hobbs, link to downunder is a nice one.
Anybody ever run the Enya 180??
Curious.
Old 09-14-2005, 09:34 PM
proptop
My Feedback: (8)
proptop's Avatar
I have a 4 stroke Enya .80 in a Pica 1/5 scale Aeronca Sedan...
Also...an early 70's .09TV and .35TV IV that's got like a bazillion "miles" on it
Old 09-14-2005, 10:56 PM
Phil Heller
My Feedback: (9)
4 strokers all! Good power, user friendly, and they last forever! I have a 90 (21 yrs old!)
an 80 ( 20 yrs old), 120R ( 20 yrs old), and a new 155R(a real sweetheart of an engine).
I run them all on Wildcat 20-20. 155R is in a new Rascal 110, a good combination. All are no tinkering, just fuel them up, fire up the Glo plug and FLY. Interestingly, 3 are mounted inverted and one is side mounted - all are happy!!!
Great engines.
Phil
