Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Octura M435 vs. Octura Y535??
Reply
Old 02-06-2006, 09:09 PM
rcboatnrules69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Octura M435 vs. Octura Y535??
what is the big difference in these two props?? i want to buy a new prop for my budweiser 1/12 and was wondering which one would be the best for the job.. iv herd from others that the M435 is a lifting performance prop..
thank you
ID:	403359   Click image for larger version
rcboatnrules69 is offline
Old 02-07-2006, 08:12 AM
jdoug
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Octura M435 vs. Octura Y535??
1 has 2 blades the other has 3. Judging by your pics.
...No seriously...I've heard the Y535 is a great performer on the Miss Bud. If true...the 3 bladed 35MM might be to much prop to push. I would go with the Y535. Generally, if top speed is what your after (trust me you are, especially with a hydro) then you could with a bigger 2 blade prop vs. 3 blade...which will push your boat farther in 1 revolution than the smaller 3 blade. Hence...it will be faster.
jdoug is offline
Old 02-07-2006, 10:54 AM
jdoug
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Geez, I should of read that. Didn't make much sense at the end.
I would think that a bigger 2 blade would be better and faster than a smaller 3 blade prop. A 3 blade prop will put more of a load on the engine which is why you would have to go down in size.
jdoug is offline
Old 02-07-2006, 11:35 AM
330T
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you run standard 20% fuel the Y535 is a replacement for the stock prop. I started running 30% and then to %40 and it flew with the y535 but after a few hours i threw out the bushing in the connecting rod.
I'm now looking to move to a Y536 or Y537/3 Not a fan of the 3 blade but there is no way i can make the jump to a Y547...
I have on order for another boat a Prather 215 and May... try that.
330T is offline
Old 02-07-2006, 04:21 PM
rcboatnrules69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you for the info.. ill give the two blade Y535 a try.. and post my results for sure.. also if anyone has any info on moding this boat let me know.. i just want to get more power without spending big bucks.. maybe increase the % of nitro from 20% to 40%??
Old 02-07-2006, 10:16 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Octura "M" series of props are kind of what the letter stands for, Modified. These were X series props with some of the tongue area removed for better performance. Boaters have found out that the extra tongue was actually slowing the boats down!
There has been an arguement going on with the props guys as to the merits of 3-blade props. When used in a lifting capacity, the 3-blade will hold up the rear of any hydro up better than a 2-blade. The M props are not lifting props.
The X-435's have been used on the Miss Bud's with good success as they have less of a problem with cavitation.
Ron Olson is offline
Old 02-07-2006, 11:20 PM
rcboatnrules69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks Ron .. i also was wondering if changing the % of nitro would help or will it just blow the motor sky high? iv been running 20% sidewinder .. is there anything better for more performance?
Old 02-08-2006, 12:02 AM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure, you can go higher, it freaks out the car guys! I run 50% in all of my boats from the .12's on up. I don't know what's available on your side of the Great Lakes.
Work on getting everything set up, from the motor to the prop then mess with fuel.
Old 02-08-2006, 09:29 AM
rcboatnrules69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks.. i will for sure.. and ill definatly be looking for some stronger nitro to try now lol..
Old 02-14-2006, 10:23 PM
mybudisfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just recemtly purchased a 1/12 scale bud, and have been tricking it out to the max.........there are all kinds of mods for this boat, and the .15 dynamite marine engine that it comes with. If you're interested in some of my mods.....get back to me, and I will be glad to contact you. Yes.....the y535, is the prop of choice for improving performance from this boat. I intend to try the m435, but I supercharged my dynamite, for extra horsepower. As far as fuel is concerned, I wouldn't run anything over 30%, and Dynamite recommends replacing the rod after every (2) gallons of fuel...just FYI
Budman
mybudisfast is offline
Old 02-22-2006, 11:58 AM
rcboatnrules69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey thanks for the tips.. ya i just was looking at the superchargers at RB Innovations and they are to costly to try but im upfor anything else you have to tell me about moding my bud..
Old 03-12-2006, 08:58 PM
wingswest
wingswest's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For some reason when i first go this boat from my LHS about 3 years ago or whenever the Miss bud first came out, i was one of the first to get one from my LHS, they put me on 10% blue thunder. I have not used the boat that much and have not even ran a whole gallon through it. Once i finish off this can can i go up to 30% or do i have to do 20% then 30% then 40% then 50% and so on. Is it ok to make a jump from 10 to 30? Thanks, Cameron
wingswest is offline
Old 03-13-2006, 08:07 AM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, you don't have to slowly step up the fuel percentage. I run the same percentage in my engines from day one and that might be 50% but I'm a little crazy. Just richen the carb when you up the nitro.
Old 03-13-2006, 03:39 PM
wingswest
wingswest's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool, I only have a little left in this can so i guess i will hop up to 50%, or w/e is availiable that is up their at my LHS, cuz i like living on the edge as it seems you do. What kind do you use? Does car nitro work? Thanks, Cameron
Old 03-13-2006, 03:46 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nope, I use fuel made for boats. I look for it to have an oil content of 18-20%. I use this even in my .12 powered boats that are using car/truck engines.
I love saying at the LHS's that I run 50% nitro and can say it with a straight face in my .12's, they drop their jaws!
Old 03-15-2006, 08:18 PM
wingswest
wingswest's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What type of fuel are you using and do i need to change the plugs? The only 50% i have found is on towerhobbies and its O'Donnell. Is this what you use http://www2.towerhobbies.com/cgi-bin...?&I=LXKRW4&P=0 ? Thanks, Cameron
Old 03-15-2006, 08:52 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm running McCoy MC-9's in my boats.
I've used O'Donnell and hated it. I bought 2 gallons of it and afterwards found a lot of a creosote build-up in my headers and tuned pipes. Some people love it and there is no disputing that it has been used in a lot of record setting boats but this is my findings on it.
I've used Byron's, Red Max, Ritch's Brew and Wildcat all with good results.
Old 09-25-2006, 12:29 AM
SigMan
My Feedback: (21)
SigMan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DONT BE AFRAID TO USE 50% NITRO OR HIGHER , JUST MAKE SURE ITS HIGH QUALITY FUEL WITH AT LEAST 18% oil ! , just make sure you can always see a slight smoke trail when running the boat , if not, richen it up quick ! i use 60% o'donnels and im having excellent results so far after 25-30 tanks thru it , proud to say, MY MISS VEGAS ROCKS !!!
SigMan is offline
Contact Us Archive Advertising Cookie Policy
