Reload this Page >
Remove color from an anodized spinner?
Old 07-25-2013, 07:23 PM
Cub_Boy
Cub_Boy's Avatar
Default Remove color from an anodized spinner?
I purchased an anodized spinner for my World Models GS Zero however the spinner has a spiral stripe and color I would like to eliminate.
Anyone know if it possible to get the spinner back to bare metal color so it can be repainted?
Old 07-25-2013, 07:28 PM
Gizmo-RCU
My Feedback: (27)
Default RE: Remove color from an anodized spinner?
I just did one, used 400 grit wet paper and remove the finish. I then polished the spinner on a wheel and I left it that way. It looks about as good as you could ever hope to achieve ! Guess I could spoil it with paint?
Old 07-26-2013, 06:42 AM
Cub_Boy
Cub_Boy's Avatar
Gizmo-RCU, sounds like a good idea I will certainly try it!
Thank you for the suggestion.
Rick
Old 07-31-2013, 07:12 AM
kenh3497
kenh3497's Avatar
Oven cleaner will also remove the anodizing. Don't leave it on to long though.
Ken
Old 07-31-2013, 07:19 AM
Cub_Boy
Cub_Boy's Avatar
Any particular oven cleaner?
Old 07-31-2013, 07:53 AM
vicman
My Feedback: (10)
vicman's Avatar
Glass bead blast with low pressure.
Old 07-31-2013, 02:31 PM
Cub_Boy
Cub_Boy's Avatar
I tried the suggested method of using oven cleaner to remove the anodized coloring. This actually worked really well; I soaked the spinner and back plate then let them sit for about an hour.
The ended up with a black crust on them; all I had to do was use my dremel with a wire wheel and knock off the crust and I was down to bare metal. Worked like a dream and using the dremel
to take off the black crust did not take very long at all.
I have one of Frank Tiano's out of print color chip books (Great resource...wish he would print more of these!), compared my photo of a spinner on a full scale and got as close as I could with
an off the shelf rattle can. I used Valspar Paint + Primer and chose the color that was as close as I could get which was a bout 2 shades off the color of my full scale source. However I do not
think 99% of the people who will see this will never even be able to tell that the color is just a bit off. Once the paint dries I will give it a shot of automotive clear coat and it should be good to go!
ID:	1905025   Click image for larger version
ID:	1905026   Click image for larger version
Old 07-31-2013, 03:51 PM
vicman
My Feedback: (10)
vicman's Avatar
Looks pretty good!
Old 08-01-2013, 06:53 AM
LesUyeda
Banned
"I have one of Frank Tiano's out of print color chip books"
Two things to remember about published colors. Printed colors do not accurately reproduce the oil/dope/pigment because printers ink is not the same.
Color chips, if actually painted, have the same problem as real paint; they oxidize, and change color over time.
Les
Old 08-01-2013, 07:00 AM
Cub_Boy
Cub_Boy's Avatar
Hi Les,
You are right on the button with that; unfortunately all of this stuff is subject to individual interpretation and you have to have a starting point.
This plane will never be a contest plane... I will over time add details here and there to dress it up a bit and keep it interesting. Getting the
exact spinner color was not really my goal on this one; I just wanted to get close enough to make me happy with the look of it
Rick
ORIGINAL: LesUyeda
''I have one of Frank Tiano's out of print color chip books''
Les
