RCU Forums - View Single Post - Loaded Dice CG
Old 07-02-2007 | 09:00 AM
kiwibobby
Default Loaded Dice CG
I have been given a Loaded Dice with hanno special by a friend, but don't have the CG.
He removed the servos, which were a low profile type. I had to relocate them differently to fit.
I tried to calculate using CG calculator I found on the Web, it comes out as 5 7/8" from the LE.
Can anyone confirm that this is about right.
(Wing root chord is 16", wing is swept back at LE, and straight at TE)
Thanks in advance for any advice
Bob
