NiMh batteries charged in NiCd mode (multiplex)
FL
Hello,
By mistake I charged a new TX pack I built with new NiMh Sanyo 2500 with a Multiplex 5014 in NiCd mode. Before I noticed, they were charged up to 1600mah. The charge was at 200mah. I stopped the charge and switched the mode to NiMh and am currently charging at 200 mah/discharging at 500 mah (cycle) 4 times.
What damage if any may have occured to these brand new batteries????
Thankyou,
Joe
Thankyou,
Joe
![](/forum/images/badges/trading_plus_member.png)
I don't think you could've harmed them at that charge rate. The difference between Nimh and Nicad charge types is peak sensitivity. When form charging a new pack, you WANT to go past the peak with C/10 rate to equalize the cells. Some folks trick their chargers into form charging a Nimh by setting it to Nicad so it won't peak.
Form charge is a slow (C/10) charge for ~16 hours. If your charger can't do 250mA then 200mA for ~19 hours should do the same thing.
My Feedback: (54)
ORIGINAL: gerwen
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
My Feedback: (16)
GA
Do to the low charge rate, no damage was done.
If any damage was done it was from stoping the charging process before it was completed. The need for a NiMH specific charger is only for peak charging not overnight charging.
