does anybody know? reflex question!
NY
im making a indoor/ outdoor flier out of my reflex, but am curious as to the max range of the reflex. anyone know? thanks chris
My Feedback: (10)
CT
Not sure what you mean by the range, which would be limited by the radio and receiver.
If you mean flying time, I see that the Reflex from Hobby-Lobby uses a 3S 800mah pack and weighs 13oz. My own experience with a foamie plane just a bit heavier, with a 3S 1000mah pack is that the plane will use from 80-110 mah per minute, depending on what you are doing, so you could probably plan on flying your Reflex for 5-10 minutes on the recommended pack.
Hope this helps !!
Hope this helps !!
NY
that does help some, however by range i meant that i need to know how far the reflex can travel from the radio. im turning the reflex, an air hogs rc helicopter, into a 3 channel plane. but needed to know the range that it has so that i can decide if i want to make it a slow, mostly indoor flier, or a bit faster outdoor flier. thanks, chris
