Groovy 50 F3A
MN
Groovy 50 F3A
Hey guys, I am new to electric pattern so I wanted to set up my groovy to fly sportsman sequences. Just wondering if anyone thought this would be to heavy and overkill for power?
AXI 4130/16, 80A speedo, 6S-4200, 14-12E,
Motor Calc
167 ounces of thrust
45A
925W
7200rpm
Motor Calc
45A
925W
7200rpm
RE: Groovy 50 F3A
I have a Groovy 50 with Plettenberg Orbit-25/16, 5 S LiPo 4300 mAh and a 14x8 porp. It has 930 W and it will give this plane good power. I have now problem to practise P-09 at winter with that plane.
/Kristian
/Kristian
VA
RE: Groovy 50 F3A
yup 900 watts does nice , its a 5s plane
use axi 4120/18
70 amp controller
5s1p 3700 to 4350ma packs (short brick style)
14x10 to 15x10e prop
5.5 lbs great performance
you will need taller gear to clear 15" prop
Kevin
use axi 4120/18
70 amp controller
Kevin
