blade cp o-rings
AK
blade cp o-rings
Any one have a fix for the orings on a cp? Ive keep having to change mine and/or use more dampening shims. I currently have 4 on each side and its still loose. I could file the ends of the spindle(brand new) to tighen it up but would like to avoid doing that again.
WA
RE: blade cp o-rings
Hi
You could try and find some one to drill the holes just a tiny bit deeper and then use blade grip bearings instead of o-rings. I don't know how well that would work but its an idea.
I had to file the ends of mine to get a slop free fit. I used a high speed cut off wheel in my dremel tool and just took off a little at a time. If you take large cuts to the spindle ends, you run the risk of damaging the internal threads. I shaved mine down until I could just fit one shim on each end with no play. I have done this the one replacement spindle, and had to do it with the spindle in the bell hiller upgrade as well.
