Hyperion Charger Question
Long time R/C'er. New to electrics. Converted my Hangar 9 .60 Mustang to elec and everything works well. (Tunringy .90 motor, Plush 80 ESC, 5000 ma, 6S pack). Hyperion AC/DC charger. When set to "Store" with one of my packs, the process reaches a point where the display alternates between "Store" and "BLC" (which I assume means balance). Current in/out remains at + or - 0.0 and the pack voltage remains the same. Problem is, the process then seems to continue indefinitely, rather than shifting to "END". I use the balance connector at all times so far, for charging, etc. It's as though the charger is stalled and having an issue balancing the pack. Any suggestions? Do I have a defective pack?
Thanks in advance for any info.
