throttle servo
throttle servo
Hi,
just wanted to know what servo would be best for throttle on a 30cc gasser? I read somewhere that you would want higher resolution metal gear servo for throttle for better response once the ignition curve is set
Ameyam
Ameyam
RE: throttle servo
I just use a standard size/torque nylon geared servo on my throttles. I would tend to think that if one were to encounter throttle servo problems, it would be from engine vibration transmitted through the linkage to the servo and causing metal geared servos to wear and get sloppy. I haven't seen or heard of this however; it's just my theory. Never had a problem with standard servos myself.
AV8TOR
AV8TOR
RE: throttle servo
I use good quality standard servo and good quality mini-servos and have had no trouble on medium and larger gassers. I have had trouble with lower quality minis mounted closer to the engine and I believe that was due to vibration. I have used a standard size servo on the firewall with no problems.
RE: throttle servo
I do not know where he got that HI speed servo Idea...a long arm on the carb end helps and setting the correct throttle curve is the way too go..............
