DLE 55 Beware of potential serious failure.
Hi All.
Thought I'd post a heads up to a potentially dangerous failure that I have had on a DLE 55 - and never experienced before.
The story...
Whilst flying I notice an unusual noise...
Land and inspect - nothing obvious found...suspected cowl vibration/resonance.
Took off again and moments later engine cuts.
Retrieve model and notice that the prop hub had migrated away from from the engine casing ( Front bearing housing).
Start to remove spinner and prop bolts - and the lot falls off!
So - reminder to us all...Take care when starting your engines - and never stand in front whilst running!
Happy landings
Am6.
The story...
Happy landings
Am6.
Hi All.
The story...
Happy landings
Am6.
The story...
Happy landings
Am6.
Nevertheless, Certainly good advice and I would not want it happening to my 55s. I'm not sure if there is any treatment we consumers could put on the shaft threads to avoid any issues.
Dear all I am a newcomer both to the site and gas engines. The DLE 55RA is infect my first gas engine and powers my 30% thunder tiger yak 54. I bought the engine a year ago and made 70 flights of ten minutes each. To date I didn't encounter any problems considering the fact that the aircraft is flown at extreme aerobatics flights. I had only one dead-stick because I used a plastic clevis instead of a ball link at the throttle servo arm --big mistake.
The only thing I am concerned about this engine is a particular noise that one hears when you jiggle the spinner or the prop. This noise was present when I took the engine out from the box so it wasn't developed due to wear and tear. Do you think this engine will end up like yours?
Thanks in advance for the info.
My Feedback: (19)
Considering the fact that you can get a DLE 55RA for approx 400 euros and DA 50R for 600 euros from Europe, obviously dle engines would be more attractive for the same power perhaps not reliability. DA has to make customers perceive that a higher cost is for having better quality, performance and reliability. Also it depends on the usage of the engine and perhaps I should opted for a DA for my type of flying.
Thanks guys I will keep you informed how the engine is behaving.
Manvel
FWIW I have a number of DLE's (and a couple of DL's from the early days).
Apart from one small end failure (unfortunately wiping out cylinder/piston) they have all behaved well.
Nearly all of the minor issues that I have experienced with these engines over the years has been either operator error (mine) or other components (battery/silencer etc.).
Unfortunately however, with this mode of failure, I can see little in the way of being able to check or predict that there 'may' be a problem.
But - with the thousands out there (and the fact that someone often only writes about a problem) it seems likely not to be a common occurance.
I will not be pulling all of my others apart to inspect them - for something that I may not see?
Just be mindfull that this 'can' happen.
Note... In this instance...
Prop was tight (beila 22 x 8).
Prop was drilled/fitted correctly.
Prop was balanced.
Spinner was balanced.
Engine had NEVER had a prop strike.
Hard to see that this was self induced in any way??
Happy Landings.
Am6.
Prop was balanced.
Happy Landings.
Am6.
The DLE engines occasionally have a crankshaft problem/failure. Not an often enough occurrence to warrant not buying them. They are still a good engine at a good price. Parts are readily available and cheap.
The point here is, stay away from the front of the prop. It always freaks me out to see people doing full power runups, or even just hanging out, in front of a running engine. When I start an engine, I can't WAIT to get behind that puppy where it's safe. I never let other people be in front of nor along side any of my planes/engines when they are running either.
AV8TOR
AV8TOR
Sometimes we take everything for granted and put ourselves in danger without realising the consequences. This is a very important safety issue to observe especially when playing with such powerful engines. This is my first DLE 55 engine and so far no major issues and I am quite happy with it, now time will tell whether this will be the first and the last DLE engine for me. According to other threads the majority of dle engine owners are quite satisfactory and invested in other DLE machines.
manvel
manvel
Dear All, I installed a new engine from the box a DLE55RA for breaking in on my model. After many attempts to flip start the engine and no signs of live I gave up. However, when I coupled the engine with my electric starter the engine sprang to live and works perfectly.
Any clues why it is refusing to hand start.
Thanks & best regards.
My Feedback: (19)
Thanks guys, yes it is lack of fuel. The engine is improving and fires after 25 hand flips and getting better. The choke may also was contributing because it is operated with a servo and adjusted to close better.
Thanks and best regards.
