DLE 30 TUNING
AP, JAPAN
DLE 30 TUNING
Hi all. I am running the DLE-30 in my new Pilot RC 26% Extra 260. I have about 5 tanks through the engine on the ground, and 3 in the air.
It runs well on the ground. Transition is smooth from idle to max.
In the air, it sounds a little bubbly, and it died on me when I was powering up after a touch and go. I had to set it down quickly!
I am running a XOAR 18X8 with NGK plug, JTEC PITTS muffler, 32:1 fuel. Is there a gas engine tuning guide somewhere?
I am new to gasoloine engines (first one), and it is certainly different from glow tuning. Please help.
I am a fairly new pilot, and I need to have all of the confidence I can get in the air. Thanks
PILOT RC EXTRA 260 26%
XOAR 18X8
42% ZEUS V2 BATTERY ELIMINATOR
DUAL 2S 2100MAH A123 (WITH BATTERY BACKER SYSTEM)
POWER HD 9150 SERVOS
IGNITION AT 5V
XOAR 18X8
IGNITION AT 5V
PA
RE: DLE 30 TUNING
Seal!
Just GOOGLE TUNNING WALBRO CARBS and you will get all kinds of info.
Also there is also another web site to down load instructions on tunning these gas engines somewere here on RC Universe.
I am trying to find that thread and will post it when I find it.
RE: DLE 30 TUNING
Of casual interest is people buying and flying a product without first researching who they are used and operated....... That is not directed at a particular individual, but the hobby population as a whole. it would explain a great many issues people report having with various products.
RE: DLE 30 TUNING
ORIGINAL: Tired Old Man
This is what makes me Grumpy.
bcchi
AP, JAPAN
RE: DLE 30 TUNING
There are gas engine tuning guides everywhere. with one of them a sticky on the opening page of this forum. It is much to write again so please try a search sujng ''gas engine tuning'' as keywords. Your engine is set rich.
AP, JAPAN
RE: DLE 30 TUNING
ORIGINAL: spaceworm
Here is a link to a good tuning guide (I think):
http://indianatinygasengines.com/page3.aspx
Good luck, welcome to RC and Gassers.
AP, JAPAN
RE: DLE 30 TUNING
AP, JAPAN
RE: DLE 30 TUNING
ORIGINAL: DG40
Get rid of the Zeus and try again.
That thing cause me problems. I thought it was the carb but no. the zeus began to fail.
FL
RE: DLE 30 TUNING
Got a new DLE 30. Maiden at factory recommended settings for Hi and Low setting. Great engine runs. 2nd time out engine would loose rpm on vertical upline. My careless I did an avananche and engine died in the snap at the top of the inside loop. On the ground engine will always cut out when I hold plane vertical. Tried several combo of changes to Hi and Lo carbs without any success. Beginning to think something is happening in the tank. Never had this problem after one flight. Before I hassle with getting to and removing tank for dis-assembly and re-asassembly anybody have any suggestions?
Russ
Russ
RE: DLE 30 TUNING
<hr />
<hr />If when holding the airplane verticle and the engine quits....its because when new the fuel draw is not too good yet. Your engine needs more break in....stay away from strait up flight untill it gets broke in more! Capt,n
ORIGINAL: bassrussx4
Russ
Russ
