Don Smith Cessna T-50
#51
![](/forum/images/badges/premium_member.png)
CO
Joel: I'm using a pull/pull rudder. The tail wheel post and rudder are connected in the tail cone. The yoke is much easier to make than it looks...probably easier than bending one from music wire.
Doing the wing cube loading, the 25# has a cube loading of 10.39, making it more like a sport flier...the 35# has a cube loading of 14.54 making it like a warbird...I like sport better! It will most likely come out more than 25 and hopefully less than 35!
M
Wing Span 100.6
Wing Area 1642
Min Weight 400
Wing Loading 35.08
Cube Loading 10.39
Max Weight 560
Wing Loading 49.11
Cube Loading 14.54
Average Wl 42.10
Average Wcl 12.47
#52
Murphey,
Even with a CWL of 10.4 that's pushing into "scale" IMO. And forget 14.5. I have DF fiberglass jets with lower CWL
. I'm definitley going to work hard at keeping the weight down.
I like to see some pics of your P-P setup for your rudder. I was thinking of seperate steering servo for a little better ground handling and trying to keep it all internal, but then could go single servo (rudder) method.
Joel
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
Joel
#53
Murphey,
I went back and crunched the numbers some more and it looks like a full scale T-50 has a CWL of around 13.35. (if you guesstimate flying weight @ 4250lbs (dry weight +750lbs, pilot and 3/4 tank of gas)). for this 1/5 scale model that would put us at 514oz or 33.2 lbs. Sooo maybe a 28-30 lbs target might be more realistic ??? Maybe I'm panicing a little early. It's just seems like a lot of weight for a plane this size.
Joel
Joel
#56
CO
Joel: I guess at this point I can't worry about the finished weight...only try to build reasonably light. I've tried to upload a few pics but unsuccessfully, perhaps due to the issues RCU experienced yesterday. I'll try that again later.
What size prop does the 125 swing? As near as I can tell, an 18" prop is 20% of the full scale. I'm using 18X6 on the G-26.
M
#57
A 16x6 would be about the limit. It might swing a 18x4 but not with the authority of the 16. according to a couple of the thrust calcs I found, at 8500 rpm I should get approx 12.5 static thrust x2 is 25lb which should be fine. It's not going to horse it up but should be enough ??
Joel
Joel
#64
CO
They're from Tru-Turn. Hub style TT-2732-B-120 2-3/4" AT-6 120-SLOT Aluminum Spinner
Should have the landing gear back from Down and Locked next week! (converted from from air to electric) Then I can begin fitting everything in the nacelle
M
#65
Thanks....
hI'm also leaning toward converting the retracts to elec. Just not sure whether to do it myself or not. I contacted lado about actuators but 4 would cost $400+ shipping from france. I wrote "Down and Locked" the other day to get an estimate on a 7.4v refit but haven't heard back yet. What are they charging you for the conversion ??
Joel
Joel
#66
CO
Mitch Stott at D&L is great to work with! And he's in NC...not France. There are options available like seperate battery ore receiver battery, timed up and down etc...worth a try. Tell him the guy in Denver sent you! The conversion was $250 plus shipping.
M
M
#67
Murphey,
That sounds very resonable, and NC is a lot closer than France in more ways than one
. Let me know when you get yours how they turned out. As I mentioned earlier the pair I have are a salvage from a crash. I ordered a couple of parts I needed to repair them and they are due in any day.
I'm dying to get started on this thing. just have a couple of loose ends still on the bench and a couple of honey-do items. Hope to start by Christmas/New Year.
As you know documentation is weak. If you found any "gotchas" a long the way or found a particular order that needs to be followed, any suggestion are welcome.
thanks for your help
Keep us posted on your progress
Joel
Joel
#68
Helo Murphey, sorry for the very late response, got caught up in the holiday routine................beautiful work on the tail wheel, I really like the plastic hub covers........been thinking of changing to fiber, alum or plastic to cut weight.......the extra parts shown are for the drag brake and mooring eye that protrudes thru the canvas dust cover, this boot was made from a pair of old worn out tan Khakis shorts.......I cut the fabric to include the original hem so it will show the stitching at the bottom,a nice original look.........
Rich.
Rich.
#70
Joel,
take a look at post #44..........you will see four photos of Jon Larsons Songbirdcolor scheme..........Jon is also the president of a club dedicated to finding, restoring and flying real Bobcats..........the club is called "The Flying Bobcats".......google it......you will find a wealth of info on this site........Jon is also an expert on Sky King.....and, as you see in the last photo even enjoys dressing up the part........he is also an avid collector of Sky King memoribilia........there should be contact info on the site..............as it turns out, I will be using this aircraft for documentation for my own project..........except, I will be using the original AAF UC-78 that it was when Jon purchased it years ago.......This Cessna was a US Army UC-78B....no. AF-42-71814.......it wasdelivered to Minter Fieldnear Shafter at Lerdo Bakersfield California where is served to the end of the war........it waseventually sold for $400 and changed hands many times and was moved to los Angeles and Hollywood Ca........then to Challenger Airlines in Salt Lake City UT.......then to Airflight, Inc. in Seattle Wa...........then to General Aircraft Sales in Auburn Wa..........thenon 3-3-62, it was finally sold to J D. Larson, Auburn Wa...........then on 3-29-64 it went to Jon D.Larson Jr.............on 4-11-82 it went to Rick G.Larson, Kent Wa............and finally on 1-15-95 it was passed on toJon D. Larson Sr Auburn where it resides today.......Jon is theowner to this day and is currently registered as N53378....quite a colorful history......
Rich.
Rich.
