Question on prop lock nut
Concerning locking the prop nut on a four stroke engine, I’m well familiar with the nut and lock nut system supplied with the engine, but was wondering is it ok to use two regular nuts and simply tighten the first against the prop washer and tighten the second against the first?
Will it be just as safe in case the engine backfires?
I was given a s/h Saito 150 that’s missing the prop nuts (I do have the prop washer) and it’s a bit difficult for me to locate the original parts (out of stock in many places) not to mention extremely expensive when I include shipping costs…
On that big block Saito I would stick with the original nuts or similar like this. I'll dig up more choices.
https://www.truturn.com/?year_id=381...vpf-ymm-search
These are for the 125-a and are 8mm x 1.25 thread, same as the 150:
https://www.towerhobbies.com/product...AI125A135.html
EF (05-23-2021)
In 40 years of flying I’ve had two occasions in which a four stroke engine backfired.
First with a .61FS, during flight, then with a .70FS just before takeoff.
In both cases I had the manufacturer’s nut and lock nut installed and in both cases this kept the prop secure on the shaft, freewheeling, while the engine stopped.
So, from the safety aspect, using a single nut on a FS engine is not an option for me.
The only question is whether two identical nuts would provide the same service…
