i have troubles
i have troubles
i dont know how i break the diffs all the time i fixed them a while ago not long ago and out the beveled diffs in and broke the front ones is it becuse i do endos (front wheelies by brakes) i dont know plz help me out
RE: i have troubles
srry that wasnt english well not perfiect english all im trying to say is i broke the stock diffs and i put the silicone in with the 4 beveled diffs and i broke them how do u think i brake them is it becouse i do endos or what??? plz help me out
RE: i have troubles
Yes doing endo's is most likely your problem. With the savage at speed and when you suddenly lock up your brakes, the momentum still left in your savage will try and keep it going forewords.The front wheels try to keep turning whilst the front drive shaft is locked, added with the fact the front of the savage is also pitching down, adding extra weight at this time somethings gotta give and it usually the pinion gear that looses a couple of teeth [X(] Alloy diff cups and alloy diff housing help eliminate flex in the diffs when breaking also, but unless you like to replace crown and pinion gears all the time, lay off the endo's
MN
RE: i have troubles
If you are still using the plastic diff cups make sure they arent cracked. If you have done this enough you may have actually cracked the dif case and that would cause it to keep happening. If they are cracked you can either replace them with stock of upgrade to the aluminum ones.
RE: i have troubles
Use some grease and your diffs may have a better chance of survival.
I have never broken a set of 4 bevel spiders as yet, I pack the centres with heavy duty car wheel bearing grease. It adds more tractability when cornering.
10ft jumps, a year old and still going strong.
