glow plugs
MN
glow plugs
hey i got a picco 27 and i keep fouling glow plugs .... everytime i shut it down and let it sit for awhile i go to start and the glow plug is bad .... its running fine temp wise running around 240-250 tried three different brands of plugs .... so which needle do you think is problem ??? also how common if diff problems i did the rear about 2 weeks ago or so and now since i dropped in this new motor the rear went out again .. is it maybe another problem ??
OH
RE: glow plugs
I suggest aluminum diff housings...the plastic has to much flex.
1 time of flexing at some weird angle..will start to wear out the ring gear...as the ring wears it starts to slip....if you keep driving after it slips gears..you'll probably need a pinion gear too.
ALSO,be sure your bearings are good,ANY slop in a bearing or the housing around the bearing is asking for trouble.
GL
CS
GL
CS
MN
RE: glow plugs
well i bought 3 os plugs #8 and all 3 have been run thru i think i may be too rich on the low speed but i dont know ... could outside temp be a factor ??? today it was 35 and went thru 2 glow plugs i mccoy and one os #8
MN
RE: glow plugs
tried the mc-59 im thinking maybe a colder plug??? i dont know i have a traxxas plug in now and it went thru 3 tanks so far and hasnt fouled
