need some help with my range
I own a savage 25 its standard with non of the electronics changed but recently the range of the car has been rubbish, it gets about 30 meters away and i cant make it go forward or steer. Can somebody please help me with this problem.
RE: need some help with my range
Check your ariel lead. I had a bad roll and it snapped the arial off. I had range of about the same (30 metres or so). If not check your batterys and the ariel in your transmitter as a last resort. If not then it could be something to do with your RX or TX.
Hope you can fix it.
mine started to do that, and in the end the Rx blew...
in the process of changing the entire stock radio setup, its crap...
ORIGINAL: 46u
Most radios systems that come with a RTR are not very good! Buy a Spektrum and you will never look back!
http://www.spektrumrc.com/Products/D...rodID=SPM2030F , thats a spektrum...
http://www.spektrumrc.com/Products/D...rodID=SPM20300 , and thats the new one coming out next month...
