axial .28 or 32 or force .32
RE: axial .28 or 32 or force .32
Jst bought one within 30 minutes after you get on opinion [X(]
For reiable and something that cheap axial .28 or k4The top engines are lrp z.28r spec 3 and picco .28 p6...
There are others they are just the main engines.
But you will get different opinions.
If yoy want something with top end stick with a .28. If you are going from the 4.6 The axial .28 spec1 is only about 5% more power and that's on the top end. The axial .32 is a monster on the bottom, but falls on it's face beyond mid-range. If you want cheap power go for the sts .28 it can be a pian in the a double s sometime. The needles are course threaded making dramatic changes in small increments. Have not had one to last over 5 gallons yet! LRP or the picco seems to be the way to go right now. Axial .28 again is not a bad motor at all for realiablity and tunability. It is just not very much of a upgrade from the 4.6
