glitch is a *****
My Feedback: (17)
glitch is a *****
Get this, my corona 120 has no glitches when the radio and the heli are turned on. when I run the electic motor, Still NO GLITCHES. when I do a range check, Still NO GLITCHS. BUT AS SOON AS I WORK THE CYCLIC CONTROL, THE THROTTLE GLITCHES LIKE CRAZY. Even if I stop working the Cyclic Servos, The Glitches keep jolting the throttle, until I turn everything off, then when I turn the radio and heli back on again, everything is calm until I move the Cyclic servos. Is it Possible that one or both of the cyclic servos are going bad and causing the glitches? I installed a deans antenna as per instructions (didn't Help) and Im running a Mega 16/15/3 brushless motor with a Pheniox 35 ESC and 11.1v 2100 mAh Lipo battery pack. Any Ideas........[]
My Feedback: (17)
RE: glitch is a *****
Everyone whom has had the same problem has been suggesting to me to switch to the Berg Glitch proof R/C Receiver, So Im going to try that and post my results, but thanks for all your help guys, Lets see what happens next............
berg is almost glitch proof. I love mine (3 of them, 2 5channel and 1 6channel) I will not use anything else on a heli. when it gets swamped, what it does is slow down the control until it gets clear signal. (like when someone turns on a radio on your freq) at least give you chance to yell out. it did the same when my crystal start to go bad. eventually I had to replace the crystal. but again, gave me chance to get back in control and land.
My Feedback: (17)
Askman, before I order the berg receiver, I just want your opinion on something. I had just given the Heli's li-poly battery pack and the Transmitter a full charge, Then when I tried to turn everything on, the servos and throttle went crazy and raced the motor, It looked like a little bit more than just a glitch problem. Do you think it could be a defective CC speedcontrol? Im confussed right now not sure if it's the receiver or speedcontrol.......
