Roto motor 70V2-70cc
My Feedback: (57)
MO
These are new in box, not used *4.27cu in(70cc)
* STATIC THRUST 14.5 kg
* BORE 2x 39.5mm
*RPM 25X107000 Rpm+
*WEIGHT 2300g 5.0l
*props 25x10 /26x10*PISTON ROD4x NEEDLE BEARING TORRINGTON
*CRANK SHAFT2x NSK + 1x TORRINGTON
*IGNITION PROCESSOR CONTROLLED
*FUELGAS+OIL MOTUL 600 "Amsoil 1:40
* BORE 2x 39.5mm
*RPM 25X107000 Rpm+
*WEIGHT 2300g 5.0l
