2.2 M Viper Jet Trainer V4 in Mercedez * Ferrari Color scheme
2 meter viper newly produced by the team targetting jet modellers looking for Mid-Size jet trainer. Fuselage is in composite and the wing is built up with carbon fiber material, light and strong. The wing structure had been tested with 75kg weight on the top. The plane had been tested. Complete retracts well made.
http://www.austars-model.com/22-mete...es_g16602.html
The Viper Jet is a small homebuilt jet aircraft by Viper Aircraft Corporation. It is a conventional, low-wing monoplane with swept wings and tail and two seats in tandem under a bubble canopy. The jet intakes are located at the sides of the fuselage and the tricycle undercarriage is retractable. Construction throughout is of composite materials (info Reference from wikipedia.com)
Technical Data for the RC Viper Jet
Wingspan: 86 inch (2180 mm)
Length: 78.5 inch (2000 mm)
Dry Weight: 10.5-11kg
Radio: 8-13 standard servos (optional)
Complete Electric Retracts by JP (optional)
Turbine engine: 8-12kg thrust (optional) Ace Turbine 12kg recommended
Turbine exhaust pipe (included)
All hardware (included)
Fuel Tank (included)
Key Features:
Key Features:
- CF tubing for the wing, rudder, and elevator
- CF material reinforced fuselage ribs with composite fuselage
- CF material reinforced wing (tested with 75kg weight), light and strong
- Balsa built up rudder and elevator
HI Frank:
Please check Austars record via F B, and check the giant airplanes develped by us. 110" Cessna 188 Agwagon, 120" Cessna Agwagon, 120" Cessan 182 composite, 96" Cessna 152, 98" Carribou DHC4..
For sales, you can use Paypal, which give you the warranty
Our Paypal address
[email protected]
Our Paypal address
[email protected]
shipping
Hi Shipping by airexpress to the States, around 7 days, we shipped a lot of RC products to worldwide and know how to pack and how to save the costs
This is with insurance
