NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
#127
CA
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
I can check for you. Order number? If not, let me know your name and I'll look you up.
John
Nitro Planes
John
Nitro Planes
ORIGINAL: cyborg1
Hi John,
Do you have the vortex 32 canopy (red trim) available? I cracked mine, and need a replacement. Thanks.
Hi John,
#128
CA
sure I can cehck for you. Got an order number?
John
Nitro Planes
John
Nitro Planes
ORIGINAL: ashdec87
Hi
I need a replacement canopy for the CL-415. Mine went down in the water for an unknown reason and the canopy sank..
email: [email protected]
http://www.nitroplanes.com/cacltw0en80n.html
thanks
ash<br type=''_moz''/>
Hi
thanks
#129
I need a motor for the art tech corsair
<span class="Apple-style-span" style="font-family: Tahoma; white-space: pre; ">http://www.nitroplanes.com/20ar2f4uco3d.html
the motor you sent is shot and won't work
i don't know my shipping number but my name is ted simmons
10676 county road 109
please help i haven't even got to fly it</span>
#131
FL
Order No 633056
ExceedJet_06A01-F35-Gray-24GHz
I need to order a new left wong and new aileron hinges please.
Also, I know you are out of stock for the rest of the foam, but when do you anticipate restocking?
Thank you,
Gabe Tuft
Thank you,
Gabe Tuft
#132
John,
You seem to be the go-to guy for NitroPlanes questions. I found a free shipping code for $50 in replacement parts, but when I tried to order them, I couldn't get the shipping deal. I need a couple of landing gear for the Swallow 90. I have one of those, as well as a Quest 90, and the gear appear to be the same!
Kevin
Kevin
#133
Hi John
Sorry, I don't have the order number for the vortex 32 as the plane was given to me as a gift from a friend that went to the US on holiday. If you do have the canopy for the vortex 32, I'd like to order 1 from you if possible. Thanks.
#134
I need to get a replacement fuselage for your EDF f-16 ...http://www.nitroplanes.com/f-16-edf-rc-jet.html.. You can contact me at [email protected]. Thank you
#136
My Feedback: (93)
IN
john hello hope you get this im in dire need of instrction manuel for the 120 size zer0 can you help me out you can reach me at
[email protected] i also need the frt landing gear for my f18 c thanks stan smith
#137
CA
Hi I got this part for you and it's $7 shipped to you. Can I charge this to your card under this order?
John
Nitro Planes
John
Nitro Planes
ORIGINAL: dahungkee
Hi,
I bought a Art Tech F4U last week. But being a first time ''pilot'', I crashed my plane in its first flight. I can fix a lot of stuff by glueing them back together. However I need to find one replacement part as noted below. Thanks a lot and looking forward to hearing from you!
Order Number: 630147
Description: a plastic mount to mount the motor to the plane's main body inside its nose. It has a square base on one end with 4 screw holes for connecting to the plane, and a round base on the other end to mount the motor.
Hi,
#139
FL
Had my Edf f-35 jet for about 3 or 4 weeks and I love it! But today before I even got in the air the jet stopped moving on takeoff. Apparently all the fan blades had snapped. Motor still turns just fine. Can u please send a replacement?
If it can't be removed and replaced without opening the fuselodge I think it's only fair to send a new one out as well.
Thanks!
Gabe Tuft
Thanks!
Gabe Tuft
#140
Hello. I ordered a replacement canopy for my Bobcat 50, and although I ordered a yellow one, I received a red one. Can you please send me the correct canopy? Order number: yhst-17210252890263-95356 for a Canopy - Yellow NitroModels Bobcat 50.
* Christopher Susicke
* 148 Central Ave
* Apt. N1
* West Caldwell, NJ 07006
* 973-432-6817
* 148 Central Ave
* Apt. N1
* 973-432-6817
#142
ORIGINAL: gabe_tuft
Gabe Tuft
Gabe Tuft
Remember that you must balance EDF rotors and "break in" the fans using proper techniques, including and not limited to sanding the fan tips to obtain proper clearance.
#143
FL
That kind of defeats the purpose of "Ready To Fly". I shouldn't have to take an rtf jet apart and sand the blades. Please send me the replacement blades and I will take the thing apart myself.
#144
ORIGINAL: gabe_tuft
That kind of defeats the purpose of ''Ready To Fly''. I shouldn't have to take an rtf jet apart and sand the blades. Please send me the replacement blades and I will take the thing apart myself.
"Ready to fly" means "ready to put a few hours of work into it".
ARF = Get ready for 20 hours plus
Kit = Spend a year getting it together.
RTF stuff needs to be prepped, trimmed out, and gone over throughly.
Newbies often do not undstand this and if they have no other help they therefor do poorly.
You can obtain the Fan via the web site as a part.
#145
FL
Well, only a newbie to planks. Been flyin helis for a while now. So I'm no rc newbie.
I'm not gonna stop buying stuff from you guys (yet), cause you have good stuff at good prices.
But man, that's awful customer service - and obviously you don't care. Bad advertising too.
#146
ORIGINAL: gabe_tuft
Often applying locktite to all of the screws, etc.
EDF's are no different, and if anything they require more attention than regular prop planes.
This has nothing to do with "service", rather newbies need to come up to speed on EDF's... that is one reason I personally do not recommend them for beginners. They are more of an intermediate plane.
#147
FL
Well, no harm no foul then. How long till your spare parts for the F-35 come back into stock? The rotors are outb of stock along with most of the foam.
Thanks.
Thanks.
#148
John ( Nitrostaff1 ) can answer the availablity question.
FYI: I've been able to substitute EDF rotors or whole assemblies from other manufacturers of identical size.
#149
FL
Can you please point me towards a link for breaking in the edf and balancing the rotors? I may just buy a whole new f-35 from u guys and keep the other one for parts. Unless you can recommend a better edf plane. I chose the F-35 based on Dave Herbert's review.
#150
I've talked about this in other threads such as this one: [link=http://www.rcuniverse.com/forum/m_8605094/mpage_1/key_/tm.htm]Click me![/link]
But the best write-up I've seen was in "Sport Flyer" magazine, I believe it was in the October 2008 issue or before then.
They went into all of this stuff in detail.
Basically if you CAN, you should try to balance the rotor on a magnetic balancer. In the article they used small amounts of tape on the inside of the rotor to balance it. They also gave details about checking the centering of the balancer itself to avoid problems...
At worst if you cannot remove the motor on a new plane, you find the point where the tips approach the shroud at their closest point.
Then you place initially a single piece of sandpaper under the tip, between the tip and the shroud, and while immobilizing the sandpaper, turn the rotor over until the rotor moves freely. Then insert a second sheet on top of the existing one and repeat.
The idea is to remove about 2mm of plastic from the tips.
The blades expand quite a bit because of the high RPMs.
2-3mm clearance is needed to prevent rubbing, motor overheating and blade breakage.
Once done, tighten everything back down, and run the motor up to 50% for a minute, let it cool down for 2 minutes, and repeat slowly increasing the throttle to about 80%.
Let the motor cool for a few minutes.
Once you get there, place a tiny bit of oil ( I use WD 40 ) on a rag and wipe the inside of the shroud.
This makes any scored areas seem to dissappear.
Now run the motor up to full for no more than 10-15 seconds.
Look on the inside of the shroud and see if there is new scoring ( the plastic will look far lighter because of the oil darkening the untouched areas ).
If not, repeat for another 10-15 seconds and check again.
Once you see no new scoring you are done. Go fly.
If you do see minor scoring, repeat the sandpaper trick.
Then the last test again.
