Is there any locating devises for when our planes go down in the bush ??
ON, CANADA
Hello everyone,
I recently lost an 80 inch wing span Stinger fun fly plane, when I lost complete radio control.
I think I lost receiver power, as the fail-safes did not kick in and the engine was still at full throttle, when it went in the bush.
I have been looking for over a week to no avail, the bush is very thick, like a jungle, and now I’m loosing hope of ever finding it.
I know there is GPS devises, but they could run hundreds of dollars.
Is there anyone out there who has a link to some reasonably priced devises, that can be installed inside the fuselage, that could locate a plane after it crashes ??
Any info will be appreciated.
BoundForHell
You can never have enough power, as you can always throttle back.
BoundForHell
ON, CANADA
RE: Is there any locating devises for when our planes go down in the bush ??
I found one that will work to about 200 ft in the bush that has it's own battery power.
Here is the link
http://www.loc8tor.com/Store/compare.aspx
Bound_4_Hell
Here is the link
Bound_4_Hell
AR
This one mounts to you plane and gives audibl alarms for different situations.
http://www3.towerhobbies.com/cgi-bin...E+alert+flight
This is what I use in several of my planes, they work very well:
http://www.c-tronicsinc.com/Product-FlightAlarmDR.htm
If you are an electronic kind of person, here you have a circuit that works with an independent 9 v battery:
http://www.sentex.ca/~mec1995/gadgets/locator.htm
If you go straight in fast, and take the radio...stop and be quiet..move the controls..listen ...move and repeat....sometimes a servo will work as a locator..I have seen it work time and again..
Just get in there while you have battery, and hope one channel is still working !
good luck !
good luck !
